@#$%&* B&S. Hard Starting....
/ @#$%&* B&S. Hard Starting.... #1
WranglerX
Super Member
A Little Bit West Of Yosemite NP
MF GC1715
OK,,, Its a B&S Intec twin 22HP in a JD L120 mower and it has to be the most miserable starting engine ever... IF it sits 6-8 days It just does not want to start (dry fuel bowl in carb?)...
When it finally starts ( resorting to jump box and prime) I can see air bubbles coming in inlet side of clear fuel filter.... Wondering if I have microscopic leak in fuel line from tank to filter that is small enough (or above fuel level in tank) that it draws air instead of heavier gas?... Writing this it occured to me that a break in fuel line may actually be above fuel level (in tank) as it comes out of top of tank so it does not leak or smell of fuel!... What do you think....
/ @#$%&* B&S. Hard Starting.... #3
Something to also check as a side note. when you close the choke make sure it is fully closing. Takes very little open movement to cause hard and no starts. Adjusted on single throttle/choke systems by loosening the throttle cable clamp on the engine and while the throttle control is in the choke position tension the throttle cable to hold the choke completely closed and tighten the clamp.
And I wouldn't get too concerned about air bubbles in fuel filter. Since on vacuum side of fuel pump acts like expansion chamber and air or more correct gas vapor bubbles in filter is normal.
/ @#$%&* B&S. Hard Starting.... #4
Yea, and the next mower you get make sure it has a Kawasaki engine.
/ @#$%&* B&S. Hard Starting.... #5
Probably a bad fuel pump or the pulse line to the pump is leaking. Perhaps even an intake manifold air leak.
B&S stands for Breaks and Scrap'em.
NOT really... Funny thing is neighbor gave me a E180 mower with 25 HP B&S that a tree fell on, it had sat for a year under a tarp and suprizing enough it started right up after motor turnover may be 6-8 timers....
Separate control cable for throttle and choke.... Yes choke fully closes....
/ @#$%&* B&S. Hard Starting.... #9
I replaced a B & S on my JD Z225 that only had about 225 hours with a new engine after countless hours of trying to sort out rough running. New carb, ignition coil, fuel lines, fuel pump, head gasket, spark plug, valve setting, etc. There is a fuel gommet on the plastic gas tank. I replaced that along with a new fuel pickup line inside the tank, too. The new engine runs fine. I gave up on the B & S which hadn't been abused, either.
This probably isn't helpful in terms of finding the problem with your machine except I know how frustrating this can be.
/ @#$%&* B&S. Hard Starting.... #10
As to what might be causing no fuel at the carb, the first thing I'd do is to check the electric fuel solenoid on the bottom of the carb to be sure it is allowing fuel to flow. Would also suggest removing the bottom of the carb bowl and checking the needle valve to be sure it is allowing fuel to fill the bowl. It could be stuck in the off position.
Fuel lines and the pump need to be in good condition. Replace fuel filter. Give it a shot.
/ @#$%&* B&S. Hard Starting.... #11
If you think about the design, once the fuel level evaporates just a little bit in the carb- the float lowers opening the inlet. These little disc pumps don't have much in them for a check valve, so it is kind of like letting the finger off the top of a straw and the soda runs back. So when cranking for the first time, the pump fills the line, then finally the bowl and it starts. Usually I see these take an extended crank after a few weeks though. Everything listed up above comes into play. Some will say an line fuel valve helped them, others need to dig deeper. The old gal has a few years on her.
/ @#$%&* B&S. Hard Starting.... #12
Doesn't take much sitting with fuel in the carb to cause the needle valve to stick especially if it is ethanol gas.
I installed a shut off valve in my fuel line and intentionally run the carb dry when I know the engine won't be started for a week or more.
/ @#$%&* B&S. Hard Starting.... #13
To try and run them dry for intermittent storage, the lower seal would be sitting in fuel either way. The mains may not be though? BTW this lower seal and the moth seal above the fuel pipe can both be contributing factors to the extended cranking cold.
/ @#$%&* B&S. Hard Starting.... #14
An anomaly. Like I said. Stick to Kawasaki....or Honda. It's not that hard.
/ @#$%&* B&S. Hard Starting.... #15
Keep a can of starting spray nearby. A shot or two, and it should be good.
/ @#$%&* B&S. Hard Starting.... #16
Kawasakis use plastic gears and more gasoline than my wifes Corolla. Id pass.
/ @#$%&* B&S. Hard Starting.... #17
That said the Intek is the worst engine Briggs and Stratton ever made. Maybe only beat by a Kohler Courage.
/ @#$%&* B&S. Hard Starting.... #18
I had a similar experience and after looking at everything I thought could be wrong it wasn't any better. I drilled a hole in filter cover so gas can be squirted in carb for cold starts and it has started fine since. In the interest of cost I use a zoom-spout bottle with gas rather than starting fluid. Apparently vacuum is too weak to pull gas while using starter to let it fire a couple times and pull stronger vacuum.
Sort of what I'm doing now, yes drilled hole and use carb cleaner with the wand.... Carb cleaner is less volatile than ether...
/ @#$%&* B&S. Hard Starting.... #20
Does it bust right off with carb cleaner or is it still stubborn?
