AZ ranch
/ AZ ranch #441
I need to rent one of those to get that excess dirt out of the crawl space. That and a tiller to loosen it up and I'm in business. I can lower either one or both of them down inside with the Telehandler.
Thanks!
Mr. Fuller Lift your little Kubota over the wall and then dump out the dirt and level the gravel as you put in by the telehandler it will lift maybe 2500 lbs.
Of course may be able to sell tickets to the show of doing so.
Isn't it about time for the cold wind and snow to be getting there.
The wall does look good maybe a new door way to be put in. Kubota wide.
ken
/ AZ ranch
Last weekend I finished the waterproofing and the backfill over the foundation drain. So far this weekend I have a layer of rolled shingle, a layer of aluminum flashing, another layer of shingle, and then I just started the sill plate. I'll keep at it as long as the weather holds out.
/ AZ ranch #443
If you are concerned about frost penetration from the inside of the foundation, and can't get it back filled this fall, you could spread bales of straw around the inside foundation wall.
/ AZ ranch
When you don't have a helper, it's nice to have toys that help get the job done. Sliding a 16 ft 2x8 over 6 pieces of rebar can be a real balancing act.
/ AZ ranch
Then I used the tractor to hold the sill plate in position while I marked it for drilling holes. I have 3 sides finished now and will do the last side tomorrow unless it rains.
/ AZ ranch #446
Looks good, do you already have your logs?
What are your winters like, do you get any snow or freezing temps.
Dave
/ AZ ranch
Oh yeah. I have my logs already. I got them 18 months ago, not knowing that it was going to take 18 months to get my stupid permit.
It snows here but not that much. Usually a few inches, a few times during the winter, that only lasts for a few days. But several of the locals say we are way overdue for a 4 footer. Who knows. It will get down into the teens at night in Dec, Jan, and Feb with daytime of about 50. So in theory, I could add a log or two during some weekends throughout the winter, if it isn't too muddy.
/ AZ ranch #448
Good Morning Mr. Fuller. Back a few years ago maybe 50 working East of Seligman it snowed so could not see vehicles parked for 10 to 15 days until it melted enough to cause a bump in the snow to locate . Then had a large loader come in and clear a trail to get road to high way before interstate.
I would drive my Chev. 3/4 ton pickup 4x4 with snow drifts coming over the hood have to stop and broom off to continue driving SLOW in the snow.
Didn't want to hit a cowboy on his horse. Some of your ranch neighbors will remember they lost cattle in the freezing weather.
Pictures of logs look good have to be lighter to put up by this time.
ken
/ AZ ranch
After a 3 week delay I finally got the sill plate on the last side. Now I'm doing the center wall so I can build my pony wall. I probably won't get much more done until Spring. Time to winterize the trailer for a few months.
/ AZ ranch
It's February and it's 73 degrees at the Ranch. Oh well, I'm loving it. I borrowed a compactor from a neighbor to compact the soil in the bottom of my basement/crawl space. I used the telehandler to lower it down into the basement. The picture is on my phone, so I'll have to load it from the phone later.
/ AZ ranch
I needed to get done dirt out of my crawl space, do I rigged up my tractor bucket to the Telehandler. It works.
/ AZ ranch
Some dirt, not done dirt. LOL
/ AZ ranch
I did 6 bucket loads today. I still have a little daylight but my body said that's enough. :)
/ AZ ranch #459
Great project Bo! Subscribed.
/ AZ ranch
I'm back at it for the next week. Last time I broke the belts on the compactor and I needed to get new ones. The guy at Autozone measured the old one and said 32 inch. I thought that looked a little large, but he said the machine doesn't lie. I got a 31 just in case. The 31 will work if I run the adjustment all the way out. It really needs a 30 inch. So much for the measuring machine.
2017 FREIGHTLINER CASCADIA SLEEPER (A59905)
2017 FREIGHTLINER...
2006 Mercedes-Benz Unimog 405 4x4 Flatbed Truck (A56858)
2006 Mercedes-Benz...
2009 Honda Pilot AWD SUV (A59231)
2009 Honda Pilot...
Challenger MT275B 40HP 4WD Utility Tractor w/ 76in. Rotary Brush Cutter Attachment (A59228)
Challenger MT275B...
2014 RAM VAV 2000 TRAILER MOUNTED VACUUM MACHINE (A59823)
2014 RAM VAV 2000...
2019 GALYEAN EQUIPMENT CO. 150BBL STEEL (A58214)
2019 GALYEAN...
