Axle Breather
/ Axle Breather #1
bindian
Super Member
Willis, Texas
Mahindra 6520 4WD
Anyone got one of these...........
I need to replace this one.........
MahindraUSA has none and doesn't know when they will.
hugs, Brandi
/ Axle Breather #2
My M6040 has a breather on each axle. Dead center with a rubber hose running up high on the radiator and up under the rear seat on the rear. Both terminate with a vented, one way plug. Prevents things like mud daubers, etc from plugging the tubes.
/ Axle Breather
Can you send me a photo of the breather vented, one way plug? I make have to design something and install that.
I found two places online that have them, but they are Indian websites. I have requested the cost to ship to Texas. Guess I will find out next week if they even reply.
hugs, Brandi
/ Axle Breather
I gather the breather itself is 1/4 BSP threads. I know BSPP is British Standard Parrallel Pipe. It's all over my CAT excavator. But what is BSP? British Standard Pipe. I understand it to have a taper.
Hopefully, if I can't buy the exact part, I will remove the breather base from the stand pipe and tap the hole out for a different part number. But probably will need an adapter made for it.
hugs, Brandi
/ Axle Breather
i get mine from amazon
If I can't get the part needed to fit my tractor, I will check out Amazon. I love having no shipping costs with Prime.
hugs, Brandi
/ Axle Breather
Mahindra says around 3 months. I have two back ordered. I got a thread adapter at my local hydraulic shop, along with a vented cap. No capped breathers. The adapter is 1/4 BSPP to 3/8 NPT. I ordered two 3/8 inch breathers from easternmarine.com. BSPP is British Standard Parallel Pipe
For now, I installed the vent........
Wrapped it in scotchbrite..........
Covered that with foil to keep the dust out...........
hugs, Brandi
2009 Toyota Camry Hybrid Sedan (A61574)
2009 Toyota Camry...
ROTO-FINGER PEA - BEAN SHELLER (A63291)
ROTO-FINGER PEA -...
CROP CARE PLASTIC PLOW / LIFTER (A63291)
CROP CARE PLASTIC...
2340 (A64281)
2340 (A64281)
Caterpillar 12G/140G Motor Grader Parts and Service Manuals (A63117)
Caterpillar...
Harlo HP6500 (A60462)
