Axle Breather
/ Axle Breather #1
bindian
Super Member
Willis, Texas
Mahindra 6520 4WD
Anyone got one of these...........
I need to replace this one.........
MahindraUSA has none and doesn't know when they will.
hugs, Brandi
/ Axle Breather #2
My M6040 has a breather on each axle. Dead center with a rubber hose running up high on the radiator and up under the rear seat on the rear. Both terminate with a vented, one way plug. Prevents things like mud daubers, etc from plugging the tubes.
/ Axle Breather
Can you send me a photo of the breather vented, one way plug? I make have to design something and install that.
I found two places online that have them, but they are Indian websites. I have requested the cost to ship to Texas. Guess I will find out next week if they even reply.
hugs, Brandi
/ Axle Breather
I gather the breather itself is 1/4 BSP threads. I know BSPP is British Standard Parrallel Pipe. It's all over my CAT excavator. But what is BSP? British Standard Pipe. I understand it to have a taper.
Hopefully, if I can't buy the exact part, I will remove the breather base from the stand pipe and tap the hole out for a different part number. But probably will need an adapter made for it.
hugs, Brandi
/ Axle Breather
i get mine from amazon
If I can't get the part needed to fit my tractor, I will check out Amazon. I love having no shipping costs with Prime.
hugs, Brandi
/ Axle Breather
Mahindra says around 3 months. I have two back ordered. I got a thread adapter at my local hydraulic shop, along with a vented cap. No capped breathers. The adapter is 1/4 BSPP to 3/8 NPT. I ordered two 3/8 inch breathers from easternmarine.com. BSPP is British Standard Parallel Pipe
For now, I installed the vent........
Wrapped it in scotchbrite..........
Covered that with foil to keep the dust out...........
hugs, Brandi
2013 HINO 338 26FT BOX TRUCK (A59905)
2013 HINO 338 26FT...
2018 22ft. Tycorp Vector Belt VB-16H (A60352)
2018 22ft. Tycorp...
(6) 150 TON MOVERS (A64280)
(6) 150 TON MOVERS...
2023 CASE TV450B SKID STEER (A64279)
2023 CASE TV450B...
UNUSED AGT STSD10 SEEDER (A64281)
UNUSED AGT STSD10...
Quick Attach Grapple Bucket (A66285)
Quick Attach...
