AWS spec advise needed
/ AWS spec advise needed #1
otlski
Platinum Member
New Hartford, CT
Jinma 204, Bobcat mini Ex, Terramite TLB, Polaris quad, Cub garder tractor
Here is an off-topic post that I am hoping is okay. Unfortunately it has nothing to do with my play (the tractor) but has to do with my work.
I am looking for guidance. My company has a contract with one of the major primes. The deliverable is for a center of gravity measurement (our core competency) ground support apparatus. I have culled the following welding verbiage from our customer's SOW.
2.1 Applicable Documents
The following sections provide a listing of the applicable documents. Documents invoked in sections 3 and 4 of this document and not included in section 2 shall be considered applicable documents (unless noted as reference only).
AWS B2.1 Standard for Weld Procedure and Performance Qualification
AWS D1.1 Structural Welding Code, Steel
There are actually many more call outs but they either do not apply to welding, or apply to other materials (aluminum) or processes (brazing), or they apply to weld inspection by third party sources.
Later in their SOW, they make this statement.
3.4.8.1 Welding
Welding of SE shall be in accordance with AWS Standards and Specifications.
Note: Refer to section 2.1 for applicable documents.
I am attempting to interpret B2.1 and D1.1 and rightfully or wrongfully have perhaps reached some understanding. Please tell me where I am right, wrong, or missing something crucial. Although I have one tricky assembly where ASTM A500 is welded to 4340 steel, I am not worried about that one. I have a vendor out of state that can do the work. My immediate concern is the commodity welding where we are joining ASTM A500 to ASTM A500 or to ASTM A36. You see my long trusted local welding outfit does not meet my customer's requirements.
Specifically I believe from D1.1 either his company, and/or his welding personnel have to have a certification. When vetting alternate sources, do I ask if the personnel have the certs or the company holds them?
Can a welding outfit that does not have the certs, or guys holding that cert, hire an outside expert to stamp the work?
If our work can be re orientated to facilitate "easy" positions do the certs and thus the choices of companies and personnel open up? Is it common to find personnel only qualified for say non vertical work?
Am I correct in assuming that B2.1 is for general and specific guidance for someone who already holds a cert under D1.1? And, that B2.1 has no provisions for certification holders unto itself?
Is there an expiration date on said certs?
To meet my customer's SOW what is your interpretation of what I need to vet?
In the end, I really need a partner throughout this process. My junior mechanical engineer is not all that familiar with welding and it is not my area of expertise aside from hacking a box blade repair or similar. We need a welder that can help us make appropriate decisions, and I need a way to decide if they are competent to do so.
/ AWS spec advise needed #2
The latest AWS D1.1 book I have is 2008. I'm not finding anything on B2.1 and D1.1.
Here in the Seattle area all structural welders have to pass this test in the 3-G, and 4-G. WABO / Washington Association of Building Officials requires the welder have his card signed every 3-months. But I have had welding inspectors reject my card. Saying it was to old, and I had to retest.
Home
/ AWS spec advise needed #3
I'm a little confused on your question. Is the customer specifying certs in D1.1? Then where does B2.1 (materials) come in?
A lot of time engineers pull these specs out of a book because they have to have some sort of paper trail with the weldment. There is a lot of confusion when it comes to welding certifications. A lot of people think there is this one thing called a 'certified welder' when in actuality, there may be a thousand different certifications. Go to weldingtricksandtips.com and read Jodis' rant on certification. He explains it very well!
Thanks to both of you for your replies. I understand why my question is confusing. It came out of my confused mind. My customer only specified what I copied in my initial post. My presumption is that they are only calling out these documents as guidelines; nowhere did they use the words "shall comply" which would mean something different. So their B2.1 is meant to say "you need to pay attention to this". I almost interpret their reference to D1.1 the same way; except when I looked into it I see the all the paragraphs related to certification. That puts the two documents in a different light to me.
Not being an expert causes me to pause however. I am intending on following through on D1.1 in the strictest sense unless someone informs me differently. How I vet prospective welding vendors, and what questions are relevant to ask them is key.
Thanks, for the pointer to the rant on certification. His thoughts were enlightening and actually answered a few questions.
/ AWS spec advise needed #5
You can write up your own WPS. I use to do it all the time. Here is a blank WPS, and an example. Hopefully it will print for you! When I did this, I would write up the WPS, and submit it to the engineer of record for his / her approval.
/ AWS spec advise needed #6
Just ask the vendor to send you a copy of their certifications/qualifications and pass them on to your customer for revue.
500 BBL CEN TEX WHEELED FRAC TANK (A63569)
500 BBL CEN TEX...
2021 BOBCAT T62 R-SERIES SKID STEER (A64279)
2021 BOBCAT T62...
2011 Ford E-350 Passenger Van (A61573)
2011 Ford E-350...
2013 FREIGHTLINER CASCADIA (A63569)
2013 FREIGHTLINER...
2010 KMC 3376 Peanut Combine (A61307)
2010 KMC 3376...
2025 72in Hydraulic Grapple Rake Skid Steer Attachment (A61572)
2025 72in...
