Auger extension
/ Auger extension #11
When drilling through pipe or round stock, build a simple V holder for the pipe. Use se 2x’s. Before attacking cut one with a 45 degree down its length (table saw works great) then attach using screws or power nailer with the 45 cut exposed. Then attach the 45 cut to a wide piece of wood (1x, 2x, plywood etc) this you clamp your drill press table. Then clamp your pipe into the V and drill through both sides of pipe using a center punch to start the holes.
Perfectly aligned holes.
/ Auger extension
I have a metal V holder for pipe. Given one pipe is inside the other with wiggle room, there is an awful lot to line up. There were a couple of holes where I wasn't perfectly centered. I'm sure there are tricks for which I'm unaware.
/ Auger extension #13
Land Pride makes two extensions, I think 7" and 14". I ordered mine from a local dealer. It was expensive. It's solid 2" round bar with a 3/8" thick collar at the top. This was also before I bought my welder :)
The biggest problem I have is the flutes don't come up to the top of the hole to clear the dirt.
/ Auger extension #14
Has anyone tried to add flutes? Maybe a series of half circles welded on at a angle?
/ Auger extension
You are correct. I can't pull it out of the hole, and only a couple of the flutes are exposed. However, there is enough dirt above the flutes and in the first couple that it is still effective.
Along those lines, one note I would make is that you are leaving some amount of loose dirt in the hole. We learned that a heavy post would sink about 3-4" lower what I was reading with a tape measure when I was measuring the depth of the hole.
/ Auger extension #16
Learned on the Ford 850 that if we got the bit stuck in the ground from root or rock while drilling a hole we could turn the tractor off, jack a rear tire up and in reverse gear turn the tire to unscrew the auger. Saved a lot of digging. The tractor did not have live power pto.
Pipe is not consistent or strong compared to tubing. Good tubing can be found online or thru metal supermarket.
GENIE SUPER LIFT CONTRACTOR (A60736)
GENIE SUPER LIFT...
GRID SHAPED BUCKET FOR MINI EXCAVATOR (A58214)
GRID SHAPED BUCKET...
iDrive TDS-2010H ProJack M2 Electric Trailer Dolly (A55851)
iDrive TDS-2010H...
Westerbeke 6EKOD-CP1 6kW Marine Generator (A59231)
Westerbeke...
2018 John Deere TX (A53317)
2018 John Deere TX...
2025 ZJG ZJ-380 Mini Stand-On Track Loader Skid Steer (A59228)
2025 ZJG ZJ-380...
