Attention Machinists
/ Attention Machinists #1
loudhornsrule
Can a machine shop make me a hub to fit this shaft? I can't find one. Roughly 4'' long 1 5X8 X 1 3/8 tapered shaft with 7'16 keyway. thanks IMG_0356.jpg
/ Attention Machinists #2
Yes, they can. In addition it needs to calculate a cone angle and required length of hub (not roughly, but exactly) minus gap between housing and a hub. Take into account a new hub is in line with the other hub(s) or pulley(s) on a machine.
https://www.easycalculation.com/trigonometry/triangle-angles.php
Have ordered that at the machine shops successfully a couple of times.
/ Attention Machinists #3
The hard part would be putting the keyway in on a taper. None of the places I worked had the equipment to do that.
/ Attention Machinists #4
The turner can do it.
He just looked if he has an extractor of required keyway dimension. I didn't see the process, but that was not a problem for him.
/ Attention Machinists #6
An extractor in this case is a special tool to put a keyway inside a hole.
I'm sorry for my English which probably confuses.
/ Attention Machinists #7
Sorry. I was reading this and saw where you are from,and thought you mite be American living in Europe.
/ Attention Machinists #8
That would be a broach. Need a tapered plug to press it thru.
Op, do you have the old hub? Show us a pic of it. My guess is that it will cost you some good money to get a 1 off custom hub made.
/ Attention Machinists #9
Putting the keyway in would be very simple,indicate the taper in and cut it with a end mill !!!
/ Attention Machinists #10
Internally on a hub?
Where are you loudhornsrule? Did you find an alternate? How much would you be willing to pay?
/ Attention Machinists #11
A tapered bore with a key way would NOT be a difficult group of features to produce. A shaper would make the keyway a breeze
/ Attention Machinists #12
My bad , I was thinking he needed a new spindle made !
/ Attention Machinists #13
I was ready to say that halfway thru' reading pg 1. :laughing: Could also be done on a mill or lathe (set up for shaper op) by any machinist. A keyway broach bushing could be cast of woods metal for a one-shot, too.
Tricky part would be duplicating the taper accurately with good surface finish. (1-2hrs, mostly setup) I'd expect most 'declines' to be based on cost/time to do both right.
Might turn an original shieve/sprocket into a hub and bolt/weld that to a bore in what's desired, depending on what's on hand that came off the shaft, of course. tog
I'm in north texas. It goes on a drilling rig that I am building. Probably just gonna weld a hub on there with a chain sprocket. I know I know Don't do it, but this is holding up my progress on this thing.
/ Attention Machinists #15
Right. This is exactly what I had in mind. Thanks for training. :drink:
/ Attention Machinists #16
It would be too much honour for me. :confused3:
/ Attention Machinists #17
Have you considered sourcing a hub for the motor? This isn't exact but I'd imagine that they all have the same taper so it should be adaptable. Hub for wheel motor.
Yeah, I ordered a couple random hubs from them, and nothing would work. Thanks
/ Attention Machinists #19
What if you'd bring a motor to a well doing machine shop and ask them to make a correct hub for it? Before that you need to know and to tell them a required hub's diameter and its thickness according to its being in line with the other hub(s) or pulley(s). Most shops in my area have employed the constructors and/or technologists to correct an order. I'm sure you may find one, or even much better, around you.
Landhonor Mini Skid Steer (A60352)
Landhonor Mini...
ROANOKE S/A LOOSE LEAF TRAILER (A63291)
ROANOKE S/A LOOSE...
ROANOKE G195 BRUSH-AX LONG ARM MOWER (A63291)
ROANOKE G195...
429888 (A61165)
429888 (A61165)
KUBOTA M108S TRACTOR (A64280)
KUBOTA M108S...
CASE IH MXM175 MAXXUM TRACTOR (A64280)
CASE IH MXM175...
