Attention Machinists
/ Attention Machinists #1
loudhornsrule
Can a machine shop make me a hub to fit this shaft? I can't find one. Roughly 4'' long 1 5X8 X 1 3/8 tapered shaft with 7'16 keyway. thanks IMG_0356.jpg
/ Attention Machinists #2
Yes, they can. In addition it needs to calculate a cone angle and required length of hub (not roughly, but exactly) minus gap between housing and a hub. Take into account a new hub is in line with the other hub(s) or pulley(s) on a machine.
https://www.easycalculation.com/trigonometry/triangle-angles.php
Have ordered that at the machine shops successfully a couple of times.
/ Attention Machinists #3
The hard part would be putting the keyway in on a taper. None of the places I worked had the equipment to do that.
/ Attention Machinists #4
The turner can do it.
He just looked if he has an extractor of required keyway dimension. I didn't see the process, but that was not a problem for him.
/ Attention Machinists #6
An extractor in this case is a special tool to put a keyway inside a hole.
I'm sorry for my English which probably confuses.
/ Attention Machinists #7
Sorry. I was reading this and saw where you are from,and thought you mite be American living in Europe.
/ Attention Machinists #8
That would be a broach. Need a tapered plug to press it thru.
Op, do you have the old hub? Show us a pic of it. My guess is that it will cost you some good money to get a 1 off custom hub made.
/ Attention Machinists #9
Putting the keyway in would be very simple,indicate the taper in and cut it with a end mill !!!
/ Attention Machinists #10
Internally on a hub?
Where are you loudhornsrule? Did you find an alternate? How much would you be willing to pay?
/ Attention Machinists #11
A tapered bore with a key way would NOT be a difficult group of features to produce. A shaper would make the keyway a breeze
/ Attention Machinists #12
My bad , I was thinking he needed a new spindle made !
/ Attention Machinists #13
I was ready to say that halfway thru' reading pg 1. :laughing: Could also be done on a mill or lathe (set up for shaper op) by any machinist. A keyway broach bushing could be cast of woods metal for a one-shot, too.
Tricky part would be duplicating the taper accurately with good surface finish. (1-2hrs, mostly setup) I'd expect most 'declines' to be based on cost/time to do both right.
Might turn an original shieve/sprocket into a hub and bolt/weld that to a bore in what's desired, depending on what's on hand that came off the shaft, of course. tog
I'm in north texas. It goes on a drilling rig that I am building. Probably just gonna weld a hub on there with a chain sprocket. I know I know Don't do it, but this is holding up my progress on this thing.
/ Attention Machinists #15
Right. This is exactly what I had in mind. Thanks for training. :drink:
/ Attention Machinists #16
It would be too much honour for me. :confused3:
/ Attention Machinists #17
Have you considered sourcing a hub for the motor? This isn't exact but I'd imagine that they all have the same taper so it should be adaptable. Hub for wheel motor.
Yeah, I ordered a couple random hubs from them, and nothing would work. Thanks
/ Attention Machinists #19
What if you'd bring a motor to a well doing machine shop and ask them to make a correct hub for it? Before that you need to know and to tell them a required hub's diameter and its thickness according to its being in line with the other hub(s) or pulley(s). Most shops in my area have employed the constructors and/or technologists to correct an order. I'm sure you may find one, or even much better, around you.
Caterpillar Service Bulletins (A63117)
Caterpillar...
2019 Takeuchi TL8 Track Loader with 72in Tooth Bucket (A63689)
2019 Takeuchi TL8...
2015 Kenworth T880 QMC 8060R 40 Ton Tri Axle Straight Boom Crane Truck (A64194)
2015 Kenworth T880...
2001 FORD SUPER DUTY F350 4x4 UTILITY TRUCK (A59912)
2001 FORD SUPER...
Kubota V3300-T-E3BG Turbo Diesel Engine - 3.3L - 84 HP - 2016 - Tier 4 Interim (A63689)
Kubota...
Caterpillar 416-442D Backhoe Service and Parts Manuals (A63117)
Caterpillar...
