Attachment Storage
/ Attachment Storage #21
I store outdoors... just out in the rain. Mower is the only implement I store protected and that is because the design of my brush hog leaves bearings exposed. Tractor also is protected. waste of valuable shop space to keep implements indoors. Just my opinion... We don't get much snow so loosing implments you might need in the winter not much of an issue.
/ Attachment Storage #22
I use the HF Vehicle Dollies, they hold 1500 lbs ea. They cost a bit more, they hold up well
/ Attachment Storage #23
I made this dolly for my wood splitter out of bed railing and scraps.Capture.JPG
/ Attachment Storage #24
I'm just now seeing how you built a support for your grader. Could you, please, send some additional photos of all sides that I may study? (tidalflats2003@yahoo.com) Thank you.
/ Attachment Storage #25
Why not just put wheels right on the splitter? This is by far the easiest and nicest splitter to get out and use, I have ever had. I realized some time ago that I was just making yet more junk by building dolleys and stuff to sit my junk on.
/ Attachment Storage #26
/ Attachment Storage #27
We put all our implements on dollies:
Sickle bar mower: Shared album - Bruce Ruhf - Google Photos
Grader and Rake: Shared album - Bruce Ruhf - Google Photos
Box Blade: Shared album - Bruce Ruhf - Google Photos
Bucket and Hog - and all the toys lined up: Shared album - Bruce Ruhf - Google Photos
New barn.. just getting things organized.. The dollies sure make it easy to put the attachments on using the Pat's quick hitch.
Super nice bearthebruce! All nice and neat and easy to pull out as needed. Great space saver. I'm inspired to build some for myself.
/ Attachment Storage #28
Always nice and neat when all spanking new! Owner is very German - I'm sort of German... Vie Vill haf Order! Yah? You Vil Do it my Vay!
No offense intended to German brothers and sisters.. it was intended to give a laugh for most of us of German decent are like this.
Gem99, the barn went up this summer and at first it was to be a pole barn - simple construction, fairly low cost. Well, we could not get past the rock on top the mountain to set the poles deep enough so a new design with a foundation had to be planned (foundation is sitting on crushed stone/concrete on top the rock). While looking at that plan and after the trees were cleared, we realized that our original plan for a 30x30 building with a 10 x 30 porch for storing implements under roof but outdoors, was not going to be feasible. Was not enough space to move the tractor around to pick up and drop implements. On to Plan C... So the building became 30 x 40 totally enclosed. Big space! The surprise in the deal was when the owner decided he was not working in a cold barn. While we are not heating when we are not in the barn, he had it full insulated with closed cell blown-in foam and then had a 75,000 btu heater put in. During hunting last month, it was so dang hot in the barn, I was shedding clothes... 40F outdoors and 75F to work indoors. NOT! I dropped that T-stat to 55 and then it was good for working!
(The property owner, he is like my brother, and he worries this old man needs some creature comforts. I love the new barn. )
Some are going to ask, "why blown-in insulation?" In theory, the closed cell foam is supposed to attract fewer critters. We'll keep ya posted on that.. Time will tell. The owner loves that stuff and uses it in most building projects he has done. Also did the crawl space under the house.. I should post the before and after pictures of that.. most scary place I ever crawled is now pretty!
We're down in Virginny next week and hope to build a work bench and do more organizing.
By the way, the main reason for the dollies is the big advantage to the them: I can easily put the attachments on the tractor in less than 5 minutes.. don't need to do all that backing up and aligning.. on and off the tractor a bunch of times... just roll up to the back, line-up the implement, bring the Pat's quick hitch up and lock it, connect the top link and when needed connect the PTO shaft... done. So much easier than it was on uneven ground outdoors.
Thanks for looking at the pics... thanks for the compliments.
/ Attachment Storage #29
We are building a house and the concrete blocks came on some very HD pallets. I decided to add some casters and test out some 3 point storage options. It actually worked our very well. Attachments are anywhere from 400 - 800 pounds and they move pretty easily. I got the casters for around 30 bucks on ebay (pack of 12 casters). How do you store your attachments???
View attachment 455540View attachment 455541
I bought 16 foot tall HD pallet wracking like you see in the big box stores. Every implement goes on a wood pallet and on a shelf. Saves me lots of precious floor space. Will work great on your nice concrete floors.
/ Attachment Storage #30
When you don't have an implement barn, FEL stuff gets parked on pallets, 3pt stuff on wooden stands
20200304_130320.jpg 20200604_150651.jpg 20200705_134456.jpg 20200909_135430.jpg
/ Attachment Storage #31
Big ugly contraption I built to store my Ditch Mower/Shredder. It's at leas six feet square.
The arrangements for accomodating forks was far too weak. One should only ever use tubing. Could be VERY Dangerous!
/ Attachment Storage #32
In my opinion, if casters don't have steel ball bearings I have no use for them. Swivel casters must turn on ball bearings. I also want hard wheels, preferably cast iron. Lastly, floor cleanliness and smoothness is your friend. :)
One of my rolling tool boxes is equipped with casters that won’t turn unless you kick the **** things around. One of those “irritating “ things that comes up infrequently enough that I won’t fix it by changing them(or the box) out.
I’ve had great luck with the harbor freight dollies but right now all the implements are out on the fence line. I HAVE to get another shed built.
/ Attachment Storage #33
Here's my outdoor storage solution for my higher $$ implements. I get giant pallets from work that machinery is shipped on, then turn them into mini lean to's. I may have to buy some longer lumber for the roof structure and then cover them with sheet metal. I made one to store my Land Pride RCD1884 twin spindle rotary cutter and one to park my grapple under. Tractor and FEL live in the shop, high $$ attachments in lean to's, and the rest of the stuff gets the sunshine and fresh air.
It's best to park them where they don't get covered with falling leaves and tree/shrub debris. In my experience, that's the stuff that collects and holds moisture and becomes a catalyst for corrosion.
/ Attachment Storage #34
My building has 16’ sidewalls and I would like to come up with a way to store implements off the floor (on the walls?) if possible, like the rear blade that is only used in the winter. Shelving or pallet racks would be easy but take up floor space and we all know floor space is a premium.
/ Attachment Storage #35
Three foot or 42" (better by far) racking across the back of your buildings is immensly (sp?) valuable storage space. Just problematic if you can't get at it. This last summer I ripped out a pile of 36" racking I got for free in favour of 42" stuff I got used. Sometimes FREE isn't the best solution.
/ Attachment Storage #36
I use the following guide lines. Anything with moving parts - tractor, mower, chipper, grapple is stored under cover in my carports. ROBB, LPGS, disk harrow, single bottom MB plow - out in the orchard on pallets.
/ Attachment Storage #37
I came close top getting racking but my space was too small for it to work. The dollies suited my needs better, but stones and bits of bark etc can make the wheels hang up so a clean floor is a must. I have a spare leaf blower I use to "sweep" the floor when needed.
/ Attachment Storage #39
Is that a Pinto in the background of photo 2? Just wondering. Jon
Definitely not a pinto. Looks like an old Toyota. Corona? (not Corolla). Not sure, but can tell it's not a pinto.
Oh, oops, was looking at the car on the left. Lol. The one on the right looks like an AMC Eagle.
2018 GENERAC MOBILE PRODUCTS MAGNUM LIGHT/WATER PLANT (A67714)
2018 GENERAC...
213091 (A64276)
213091 (A64276)
2017 Autocar Xpeditor T/A Heil V-161 28Yd Front Loader Garbage Truck (A61573)
2017 Autocar...
2012 CAT D60-6 GENERATOR (A67714)
2012 CAT D60-6...
GENERAC MOBILE PRODUCTS  MTL6S (INOPERABLE) (A68842)
GENERAC MOBILE...
500 BBL FRAC TANK (A67714)
500 BBL FRAC TANK...
