Attachment Effectiveness
/ Attachment Effectiveness #11
I added a valve (go to a hydraulic shop...not the box store; we have about 10X the pressure requirement) in line with the quick connect on my BH and what a world of difference!!
I don't have a schematic, but I'm sure that PT put a valve in line with the return instead of a two port valve; thus the hoses are a bugger to couple while running. (Forgetting this fact, I poured a gallon of oil on the ground while I had the fitting removed and moved the tractor.)
With the valve, I just leave the BH coupled....valve open while attaching front. Reach down and close it while I'm climbing back on....too slick!!!
On slight downside, I had to cap one set of my 3pt ports to get the angle I wanted without cutting off part of the fender. Not a bad thing anyway.....one step closer to my longer term goal of having an auxillary front control (for a swinging stumper or a pivoting bucket). Also, I have a mechanically adjustable top link for the 3pt [another someday] so "no problem."
/forums/images/graemlins/cool.gif
/ Attachment Effectiveness #12
</font><font color="blue" class="small">( but I'm sure that PT put a valve in line with the return instead of a two port valve; thus the hoses are a bugger to couple while running)</font>
Can you provide a little more description of what you are talking about? I am not sure that I understand the problem, or how your solution is installed.
thanks.
/ Attachment Effectiveness #13
Great then I'm set to go thanks...... /forums/images/graemlins/smirk.gif
/ Attachment Effectiveness #14
I made a new thread for this specific topic:
Hydraulic Logic
more info to follow there. /forums/images/graemlins/smile.gif
Thanks for starting a new thread. Let's get back to discussing attachment effectiveness.
Bob Rip
/ Attachment Effectiveness #16
Ahh yes, back to attachment effectiveness...I was so happy with my valve, I forgot to make a post about my trencher like a planned! /forums/images/graemlins/blush.gif /forums/images/graemlins/grin.gif
Anyway, I was quite pleased with it, still don't know exactly what Wasabi meant about it's versatility, but it sure makes a trench! Also, I found out that while it does make work easy for the backhoe: 1 trench only! 2 is too wide to stradle and wider than the 12in hoe needs.
On the down side, in SD much of the trench work is for a 6ft depth (water lines freeze with less than 6ft), I think the 2445 would handle it as far as HP, but PT only makes the 4.
Of course, I think something that long would look really cool in place of the hoe instead of quick tach. Now, I have another thing fits the PT build-it-yourself.....fodder for another thread!
BTW Bob, I see the mod effectiveness thread you just started: neat thread! /forums/images/graemlins/cool.gif
/ Attachment Effectiveness #17
</font><font color="blue" class="small">( Grapple bucket is great for working with trees and brush. It is many times faster than trying to chain things to a bucket and move them. I'd caution you on trying to pinch logs with the fangs and move them -- you can bend a fang.
)</font>
<font color="red"> Only with logs larger than this:
PS: Bent fangs can be easily fixed with a 20# orthodontic sledge hammer!!!! /forums/images/graemlins/shocked.gif
</font>
/ Attachment Effectiveness #18
I have straightened mine a couple of times with a farm high lift jack. works good. Just remember to reverse the jack.
/ Attachment Effectiveness #19
My most used and used alot attacments used at the same time. Just take one and pack materal into the other.
/ Attachment Effectiveness #20
Then take it to the woods
2019 Chevrolet Silverado 1500 RST 4x4 Crew Cab Pickup Truck (A59230)
2019 Chevrolet...
2015 CATERPILLAR 140M3 MOTOR GRADER (A58214)
2015 CATERPILLAR...
2003 VOLVO VNL TANDEM AXLE SLEEPER TRUCK (A59908)
2003 VOLVO VNL...
2018 PINSA 130BBL VACUUM TRAILER (A58214)
2018 PINSA 130BBL...
2019 CHEVROLET SILVERADO 1500 CREW CAB TRUCK (A59823)
2019 CHEVROLET...
2017 Jeep Patriot 4x4 SUV (A59231)
2017 Jeep Patriot...
