Attachment Effectiveness
/ Attachment Effectiveness #11
I added a valve (go to a hydraulic shop...not the box store; we have about 10X the pressure requirement) in line with the quick connect on my BH and what a world of difference!!
I don't have a schematic, but I'm sure that PT put a valve in line with the return instead of a two port valve; thus the hoses are a bugger to couple while running. (Forgetting this fact, I poured a gallon of oil on the ground while I had the fitting removed and moved the tractor.)
With the valve, I just leave the BH coupled....valve open while attaching front. Reach down and close it while I'm climbing back on....too slick!!!
On slight downside, I had to cap one set of my 3pt ports to get the angle I wanted without cutting off part of the fender. Not a bad thing anyway.....one step closer to my longer term goal of having an auxillary front control (for a swinging stumper or a pivoting bucket). Also, I have a mechanically adjustable top link for the 3pt [another someday] so "no problem."
/forums/images/graemlins/cool.gif
/ Attachment Effectiveness #12
</font><font color="blue" class="small">( but I'm sure that PT put a valve in line with the return instead of a two port valve; thus the hoses are a bugger to couple while running)</font>
Can you provide a little more description of what you are talking about? I am not sure that I understand the problem, or how your solution is installed.
thanks.
/ Attachment Effectiveness #13
Great then I'm set to go thanks...... /forums/images/graemlins/smirk.gif
/ Attachment Effectiveness #14
I made a new thread for this specific topic:
Hydraulic Logic
more info to follow there. /forums/images/graemlins/smile.gif
Thanks for starting a new thread. Let's get back to discussing attachment effectiveness.
Bob Rip
/ Attachment Effectiveness #16
Ahh yes, back to attachment effectiveness...I was so happy with my valve, I forgot to make a post about my trencher like a planned! /forums/images/graemlins/blush.gif /forums/images/graemlins/grin.gif
Anyway, I was quite pleased with it, still don't know exactly what Wasabi meant about it's versatility, but it sure makes a trench! Also, I found out that while it does make work easy for the backhoe: 1 trench only! 2 is too wide to stradle and wider than the 12in hoe needs.
On the down side, in SD much of the trench work is for a 6ft depth (water lines freeze with less than 6ft), I think the 2445 would handle it as far as HP, but PT only makes the 4.
Of course, I think something that long would look really cool in place of the hoe instead of quick tach. Now, I have another thing fits the PT build-it-yourself.....fodder for another thread!
BTW Bob, I see the mod effectiveness thread you just started: neat thread! /forums/images/graemlins/cool.gif
/ Attachment Effectiveness #17
</font><font color="blue" class="small">( Grapple bucket is great for working with trees and brush. It is many times faster than trying to chain things to a bucket and move them. I'd caution you on trying to pinch logs with the fangs and move them -- you can bend a fang.
)</font>
<font color="red"> Only with logs larger than this:
PS: Bent fangs can be easily fixed with a 20# orthodontic sledge hammer!!!! /forums/images/graemlins/shocked.gif
</font>
/ Attachment Effectiveness #18
I have straightened mine a couple of times with a farm high lift jack. works good. Just remember to reverse the jack.
/ Attachment Effectiveness #19
My most used and used alot attacments used at the same time. Just take one and pack materal into the other.
/ Attachment Effectiveness #20
Then take it to the woods
Sakai SV505 (A60462)
500BBL WHEELED FRAC TANK (A58214)
500BBL WHEELED...
2022 Ford F-150 Pickup Truck (A59230)
2022 Ford F-150...
2007 International Derrick Digger Truck (A60352)
2007 International...
2015 Kia Sorento AWD SUV (A56859)
2015 Kia Sorento...
2025 MACK GRANITE GR64F DUMP TRUCK (A59823)
2025 MACK GRANITE...
