Ariens Mower Compression Too High?
/ Ariens Mower Compression Too High? #1
turkeyvulture
Ariens riding mower with Briggs & Stratton 1-cylinder engine. Gradually got harder for the electric starter to pull past TDC. Replaced battery, then starter, then relay. Checked compression 210 psi. Seems too high right? My little push mower is 110 and I think cars are around that. Engine spins freely with spark plug out, BTW.
Figured combustion chamber must be full of carbon, pulled off head, no carbon, just light soot. Put back together with extra head gasket to lower compression. Still hard to pull past TDC, hard to start, still 210 psi.
WTF. How can the compression not be lower with an extra .037" thick head gasket in? Why is it that high anyway?
Advice anyone?
/ Ariens Mower Compression Too High? #3
Briggs uses a plastic cam shaft in a lot of their engines. The lobes wear down on the exaust resulting in high compression like you described.
/ Ariens Mower Compression Too High? #4
Also check the OHV valve adjustment. If they are loose, the decompression mechanism won't be able to open the exhaust valve to release the compression pressure.
/ Ariens Mower Compression Too High? #5
I wonder if the key sheared on the flywheel and the timing is advanced?
That sounds like the problem. Thanks I never heard about this compression release. I'll get in there and take a look.
Thanks but when I added the extra head gasket I adjusted the valves back to .004".
/ Ariens Mower Compression Too High? #8
A few of the Briggs single cylinder engines suffered from bad a bad compression release mechanism on the camshaft. Can't remember the series though. 98% of the time it is loose valve adjustment. Pop the valve cover and double check.
/ Ariens Mower Compression Too High? #9
Not familiar with the Briggs, but 210psi certainly don't sound too high IMO. Speaking in terms of modern autos....110 would be a well worn out engine, and likely a hard to start engine
/ Ariens Mower Compression Too High? #10
The OP could do some reading on it and recheck the engine:
Google
Thanks Dutch445, that's exactly what happened. Opened case, found parts of the automatic compression release system inside, installed new camshaft, problem solved. I gather this is a common problem, judging by the activity on other forums. Some folks insist it's a valve adjustment problem. It isn't.
/ Ariens Mower Compression Too High? #12
Great, glad it was something you could repair,,
/ Ariens Mower Compression Too High? #13
While performing the valve adjustment, a competent mechanic would assure the decompression is occurring.
I took the case apart and there were some little bits in there. Ordered new camshaft which came with the little flipper thing to reduce the compression. Starts like a dream now!
2019 Krause 8005-30 Excelerator - High Speed Vertical Tillage - 30 FT Working Width (A63688)
2019 Krause...
2014 Caterpillar 420F (A64126)
2014 Caterpillar...
2006 Xtreme Hawg Hauler (A64127)
2006 Xtreme Hawg...
ATS 13,000lb Electric Winch (A62679)
ATS 13,000lb...
2011 Chevrolet Silverado Pickup Truck (A62613)
2011 Chevrolet...
2020 Bobcat MT85 (A64126)
2020 Bobcat MT85...
