hayden
Elite Member
- Joined
- Sep 23, 2000
- Messages
- 2,746
- Location
- VT
- Tractor
- Kubota L5740 cab + FEL, KX121, KX080, Deere 6120M
Clint, I've got a second home that's off the grid. It's solar powered with a backup generator, and I plan to add a small hyro plant in the next few years.
Regarding the economics, your comparison is unfortunately apples to oranges. As I go through this, keep in mind that I'm a fan of solar/hydro and locally generated power.
A solar setup that can produce the same power that you use today (and pay $100+ per month) will cost way more than $30k. A $30k solar setup would have to be coupled with significant power consumption reductions in your home. Of course if you make those same reductions, your $100 power bill will drop too. It unfortunately turns out that the per KWH cost of commercial power is still below that of solar (figuring the solar cost of a 30 year period).
Turns out there's another fly in the ointment. Batteries. They have a limited life, and are expensive. Just the cost of the batteries assuming a 10 year life gets you close to many grid power rates.
Where I've found independent power to make clear economic sense is where a house is a distance from commercial power and the up front cost of running power lines is the same or greater than the cost of installing solar or some other independent power generation. This was my case and the economics are unquestionable.
I can see all this changing over time. Grid power is costing more and more, and solar is dropping in cost. They keep getting closer and closer, and as the solar control technology continues to improve, it makes solar as seamless to use as grid power.
I've found that just going through the exercise of figuring out where all your power is going will make you a more efficient consumer. You can save energy and money starting today, and start the process of readying your home for solar.
Enjoy it, it's lots of fun.
