Apparent Extra Part - What Is This?
/ Apparent Extra Part - What Is This? #1
Argonne
Paris, TX
JD2210, Ford 4400, Case IH 685, Terramite T7, JD 6x4 M-Gator
So what is this actuator lookin' thing on the left side of the engine on my Case/IH 685. I have a couple of guesses, but my wife says I'm always wrong.
/ Apparent Extra Part - What Is This? #4
Is it some sort of vacuum sensor? Looks like there's wire terminals on top of it?
Ah HA! Well, that really IS an extra part here in Texas. Thanks guys!
/ Apparent Extra Part - What Is This? #9
Looks like the previous owner also thought it was not needed and removed the electric wires to the actuator AND the small plastic line to the manifold that would feed the ether in.
Does your tractor have glow plugs? Most tractors with ether start like that didn't have glow plugs.
/ Apparent Extra Part - What Is This? #12
Yup, either start assist.
The switch is a rubber button under the steering wheel at about knee height.
/ Apparent Extra Part - What Is This? #13
The plastic line for the ether aid is broke off ! Check the elbow above your alternator in the intake is plugged or it can suck dirt directly into the motor. Remove the elbow and install a pipe plug.
I'll take a look and make sure it's not just open. As for the system, I'll see how it starts when it's 40 out. Right now it's starting right up without issue.
Cool. Thanks for posting the pic!
2020 CATER PILLAR D6 LGP HIGH TRACK CRAWLER DOZER (A65053)
2020 CATER PILLAR...
(4) HUSQVARNA CHAIN SAWS (A64276)
(4) HUSQVARNA...
New 5400LB, Rachet Binders and G70 Chains (A62679)
New 5400LB, Rachet...
Engine (A59228)
Engine (A59228)
KUBOTA MI08S TRACTOR (A63276)
KUBOTA MI08S...
2006 Ford F-150 Ext. Cab Pickup Truck (A61573)
2006 Ford F-150...
