Apparent Extra Part - What Is This?
/ Apparent Extra Part - What Is This? #1
Argonne
Gold Member
Paris, TX
JD2210, Ford 4400, Case IH 685, Terramite T7, JD 6x4 M-Gator
So what is this actuator lookin' thing on the left side of the engine on my Case/IH 685. I have a couple of guesses, but my wife says I'm always wrong.
/ Apparent Extra Part - What Is This? #4
Is it some sort of vacuum sensor? Looks like there's wire terminals on top of it?
Ah HA! Well, that really IS an extra part here in Texas. Thanks guys!
/ Apparent Extra Part - What Is This? #9
Looks like the previous owner also thought it was not needed and removed the electric wires to the actuator AND the small plastic line to the manifold that would feed the ether in.
Does your tractor have glow plugs? Most tractors with ether start like that didn't have glow plugs.
/ Apparent Extra Part - What Is This? #12
Yup, either start assist.
The switch is a rubber button under the steering wheel at about knee height.
/ Apparent Extra Part - What Is This? #13
The plastic line for the ether aid is broke off ! Check the elbow above your alternator in the intake is plugged or it can suck dirt directly into the motor. Remove the elbow and install a pipe plug.
I'll take a look and make sure it's not just open. As for the system, I'll see how it starts when it's 40 out. Right now it's starting right up without issue.
Cool. Thanks for posting the pic!
2018 MACK LR633 6X4 T/A SIDE LOAD GARBAGE TRUCK2018 MACK LR633 6X4 T/A SIDE LOAD GARBAGE TRUCK (A66091)
2018 MACK LR633...
John Deere TX Gator (A60462)
John Deere TX...
2015 FORD F-350 SUPER DUTY (A63569)
2015 FORD F-350...
1986 Eager Beaver B9D0W 20ft. 11 Ton Tri Axle Dovetail Tag A Long Tailer (A61568)
1986 Eager Beaver...
2019 Ford F250 4x4 Crew Cab Pickup Truck (A64194)
2019 Ford F250 4x4...
2006 INTERNAITONAL 7600 6X4 T/A DUMP TRUCK (A66091)
2006 INTERNAITONAL...
