Anything better than wire nuts?
/ Anything better than wire nuts? #41
Yep, I have a couple of pairs of Kliens 9 inch, one found in the drop ceiling left by some hapless electrician, and one set I actually bought new and are still pristine. Over the years I have found a lot of tools left in drop ceilings.
Thats usually me. Ive left hammers, klines, strippers, rtc. Not worth the trip back in the Attic to find them.
/ Anything better than wire nuts? #42
A pair of Klien lineman's pliers go form $40-$60...plus insulated handles...they are guaranteed against anything but burn throughs and loss...
/ Anything better than wire nuts? #43
OP are you by chance a lefty. Wired houses for 18 years and one left-handed helper that Twisted the wires backwards the wiring nuts would not stay on for him either.
/ Anything better than wire nuts? #44
Wire nuts should be just fine if you use them properly. I'm 51 and my dad was an electrician that I worked for a lot. I'm color blind, which is why I didn't pursue it. House wiring is fine, not too many colors. Solder and shrink wrap works good. But I'm happy with wire nuts, buy them by the gallons.
I think a lot of the problems people have using wire nuts could be eliminated by good planning. I like to run a circuit to each room. The ceiling light has a large box for junctions. I don't like to have the light fixture wires in the junctions. I pig tail makes just the final connection easy to join the braid and solid wire.
I do the same for receptacles. I chose wisely where to start/end in the room, meaning one daisy chain connection. that includes the pig tails, so 3 blacks and 3 whites. It is important to leave the wires the correct length, not so short you have to reach in the box, not so long you have the wad up the wires to get it in.
After I have it all connected, I fold the wires neatly so they will lay flat. One final push with a hammer handle. This leaves just one black, one white and a ground wire poking out. I never use the receptacle for the junction.
A quick check the circuits work....
That done, I'm ready for the dry wall hangers
/ Anything better than wire nuts? #46
Stranded wires need to be twisted together clockwise before joining with solid wire or wires which if there are multiple wires also need to be twisted together before wirenutting. It’s also very important when joining solid and stranded wires to extend the stranded wires a bit beyond the end of the solid wire(s) before putting on the wirenut. And yes the wirenut needs to be tight and the individual wires should be tested by giving them a tug to make sure they’re secure. I agree the ones without a metal spring are junk.
/ Anything better than wire nuts? #47
About pre-twisted wires. 3M video and Ideal pdf.
Bruce
  • WireNut WireConnector Instructions.pdf
/ Anything better than wire nuts? #48
Where’d you leave the strippers?🤷🏻
Asking for a friend.😁
/ Anything better than wire nuts? #49
Tried to find a pole dancer emoji...
/ Anything better than wire nuts? #50
Copy and save image. You’re welcome😜
