Anyone recognize this part
/ Anyone recognize this part #1
1930
Platinum Member
Brandon/Ocala Florida
Kubota B6100E Kubota L 2501 Kubota T1460
Seems like Ive seen something like this before, I believe it is only a small part to a much larger machine. It fell onto the floorboard from Im assuming the underneath of the dashboard of my Ranger last weekend.
It is quite heavy for its size, I believe it to be quality steel because of its weight and the fact that it hasnt started rusting even though its already been thru the washing machine.
Any guesses?
/ Anyone recognize this part #4
Probably something related to the steering tilt and/or telescoping mechanisms.
I'm headed out there now to where the truck is so I'll check it out I didn't even consider that it was actually something that was part of the truck
/ Anyone recognize this part #10
Hopefully an old one from another and not off of your truck!
Everything seems fine with my truck so who knows I guess where it came from
/ Anyone recognize this part #12
Strange that you found it on the floorboards. I'd think if it fell out, you couldn't shift.
Are you the original owner of the truck?
Do you have any friends (or enemies) that like to play practical jokes? 🤣
/ Anyone recognize this part #13
Shifter interlock? Can you shift out if park without key on brake pedal depressed?
Ill have to check it out again next weekend. I did not have any issues with shifting this weekend. I only use it to pull a water tote around the property.
Thanks everyone
2016 Ford Explorer AWD SUV (A64557)
2016 Ford Explorer...
2020 KENWORTH T880 DUMP TRUCK (A65054)
2020 KENWORTH T880...
2018 Roadtec RP190E Highway Class Wheel Asphalt Paver (A64553)
2018 Roadtec...
Wooden Glider Chair (A64557)
Wooden Glider...
2015 Mack GU713 T/A Wet Kit Day Cab Truck Tractor (A64556)
2015 Mack GU713...
2018 Bobcat E35i Mini Excavator (A61572)
2018 Bobcat E35i...
