Anyone here have bulldozer experience?
   / Anyone here have bulldozer experience? #61
your right hand running the blade most be moving at all times. Watch a youtube video of guy operating a dozer and you will see his hand always moving making minor corrections. The most important corrections will be height of the blade. Forward makes the blade go down and backwards it comes up. As soon as you you make contact with the ground you need to start going back and fourth on that handle. Quickly. Its not hard to catch on. As was already mentioned you may want find a guy to do it for you. IF you cant there is no reason you cant try. As was noted don't be afraid to take a break for 5 minutes if you get frustrated.
I should also note that track speed for a beginner should be slow. have the RPMS on machine all the way up. Put the machine in forward motion, put the blade slightly on the ground then this will be when you work that lever. Basically as soon as you feel the lever catch hydraulic pressure you just go in the opposite direction. Forwards and backwards quickly. You can worry about angle once you get this covered.
   / Anyone here have bulldozer experience? #62
I cannot operate a dozer in that manner. What I create is ripples. Slight and calculated blade movement creates smooth for me.
   / Anyone here have bulldozer experience? #63
I agree. Every time you move the blade, you change your grade, and that means there will be a dip or a hump.
   / Anyone here have bulldozer experience? #64
Yep , set the blade down and drive like it was stolen . No brainer . Kevin .
   / Anyone here have bulldozer experience? #65
When you hit that sweet spot you will know and more often than not optimal moisture is a factor when blazing in trails... too wet and it is a pig sty and too dry there is no compaction...
   / Anyone here have bulldozer experience? #66
how do you operate a dozer??? I don't know anyone that doesn't operate in the fashion i described unless your a noob and have never ran one before. What im suggesting makes the ripples. Which makes for ease of tracking through your bladed trail.
   / Anyone here have bulldozer experience? #67
Do not do this. Probably the worst advice you can give a noob. If he was seasoned then sure.
   / Anyone here have bulldozer experience? #68
So the first thing you do is create an uneven field for the tracks to run thru which creates "ease of tracking"?
I don't know anyone that operates in that fashion?
Start in the high area. Load the blade with material from that high area as smoothly as you can with minimal blade vertical movement. Push toward the low area. As you progress slightly raise the blade over a long run distance dribbling loose material into the low area spread over a long run. Repeat.
   / Anyone here have bulldozer experience? #69
Sorry, but the smoothest contours that you make will be done by not manipulating the blade. The the rapid use of the blade controls by an operator is the result of the operator feeling a grade change and compensating, not just blindly jerking them up and down.
Slow speed is excellent advice. Even if you have to throttle down a bit just to learn how to adjust the blade to maintain a flat surface.
This may be intuitive or may not be. Before getting on the machine, have a plan of where you want to harvest the soil and where to deposit it, how you want to transition that to existing surfaces and how you want the new surfaces to look.
   / Anyone here have bulldozer experience? #70
Anyone that runs any equipment I have owned or been in charge of would only run "like he stole it" one time,
he would be off it and walking.
If it's your own equipment and not on my property hopefully your own go for it, tear it up all you want.
   / Anyone here have bulldozer experience? #71
Ok so he should see the grade change or at least know what's coming. Im basically giving him the advice of how to move dirt from point A to B without jacking up his back. I have seen noobies on a dozer and while its funny it sure isn't how you should tell a guy how to run one without mentioning manipulating the blade as im suggesting. Clearly you just don't jerk the blade around thats certainly not what I said but clearly how you took it. Its why I said watch a video of a guy running a dozer. His right hand is moving all the time as does mine. Lets not make this harder than it really is
   / Anyone here have bulldozer experience? #72
Sadly I see this often with rental equipment
   / Anyone here have bulldozer experience? #73
This is what you said. I'll let you pick and choose what you want to defend.
   / Anyone here have bulldozer experience? #74
Richard and some others have given sound advice. If I had to move some sandy dirt around ( no ripper required) I'd be using a big wheel loader if it were more than a few acres. Then drag a good size float around which I'd do even if done with a cat. Track machines are easier to grade with but slow and you still have to know what your doing .
   / Anyone here have bulldozer experience? #75
I had to go back and read the OP’s original post as I had totally forgotten his exact field conditions.
After rereading, personally I would use a big land leveller with laser.
I think someone else mentioned this earlier also.
   / Anyone here have bulldozer experience? #76
I have 20 years experience of operating and training people on D9H and D10N dozers. The only thing I can add is wear your seatbelt and good luck.
   / Anyone here have bulldozer experience? #77
You might have an appreciation for this. Crappy pictures, but hopefully you can get the idea. Took these pics at Tikrit Iraq in 2006. Engineers were having troubles with Snipers. You better have a good "natural feel" for blade position cause the view of it sucks. :)
   / Anyone here have bulldozer experience? #78
But then don’t you ALWAYS use the Braille method for grading, Richard??
I can’t tell on my phone. In the first pic is that something on the gooseneck or something in the background?
   / Anyone here have bulldozer experience? #79
Thanks for posting Richard. Brings a whole new meaning into grading by feel. God bless our troops.
   / Anyone here have bulldozer experience? #80
Good thing I’ve ran a dozer before reading this thread or I’d have been scared off.
Really, it’s not that hard. Ours only had up and down, manual angle, no tilt. I loved running it as a kid.
Cummins 6-Cylinder Turbo Diesel Engine with Transmission (A59230)
Cummins 6-Cylinder...
2008 Bobcat S250 Compact Wheel Loader Skid Steer (A59228)
2008 Bobcat S250...
2018 Toro Workman HDX Diesel Utility Cart (A59228)
2018 Toro Workman...
5-6 YD BLUE LINE GRIZZLY SCREENER (A58214)
5-6 YD BLUE LINE...
Honda EM3500SX Portable Gasoline Generator (A59228)
Honda EM3500SX...
2017 CAT 315F LCR EXCAVATOR (A58214)
2017 CAT 315F LCR...
