Anyone ever built a post hole auger?
/ Anyone ever built a post hole auger? #1
Jrus
Argentine, MI
Ford 5500
Has anyone made there own post hole auger for 3 point? Thinking about using a truck axle to build one. Anyone got pictures or advice?
/ Anyone ever built a post hole auger? #2
I've heard of it. And I've contemplated it. Then I just rented one and moved on. If you do it, take pics and let us know about the build.
/ Anyone ever built a post hole auger? #3
Long ago in my area, most of the farmers who had one had a homebuilt. Most of the factory ones were owned by contractors.
Bruce
What did the farmers use to build there's with
/ Anyone ever built a post hole auger? #5
Most I saw were Ford Model T and A rear ends.
For example:
If I were going to build one now, with junkyard parts, I would start with a differential from an independent suspension car. No axle shaft and housing shortening to do.
Bruce
/ Anyone ever built a post hole auger? #6
For example:
Bruce
Ah, the good old days. Can you imagine Lincoln or Miller printing project drawings for something like that now? Lawsuits cometh, and that right soon.;)
/ Anyone ever built a post hole auger? #7
/ Anyone ever built a post hole auger? #8
/ Anyone ever built a post hole auger? #9
The ones from Surplus seem to be a good choice to go with.
I build one from an old BMW differential, put about $75 on the table for it. Frame was made from leftover materials laying around, drill is not exactly really good ($45 for a hand augur, garden use) but was good enough for testing it here on some sandy soil. Still have to make a good drill.
In this post some pics.
http://www.tractorbynet.com/forums/build-yourself/323376-some-attachments-i-made-year-2.html
Good luck.
/ Anyone ever built a post hole auger? #10
Don't forget to add a shear bolt or slip clutch!
A truck rear axle can probably handle a lot more torque that the PTO gears in your tractor's tranny can.
Good luck and show us some pictures if this thing comes together.
Ill post pictures when I get the motivation to yank the rear end outta the old ford. I'm gonna call around and see if I can find something smaller then the 250 rear I got right now. Seems like it be to heavy to hook and unhook.
Crown RM6025-45 4,500 LB Stand-On Electric Forklift (A59228)
Crown RM6025-45...
2016 Ford F-550 Venturo HT40KXX 3 Ton Crane Service Truck (A59230)
2016 Ford F-550...
2001 Pierce Spartan Model Tilt Pumper Fire Truck (A59230)
2001 Pierce...
Massey Ferguson 92” PTO-driven rear-mount snowblower
Massey Ferguson...
2016 Case CX55B Midi Excavator (A60352)
2016 Case CX55B...
2007 FREIGHTLINER M2 26FT BOX TRUCK (A59905)
2007 FREIGHTLINER...
