Any MF 165 owners....need some help
   / Any MF 165 owners....need some help #12
photo (3).JPG ok oil filter canister?
thanks aaron , so they are both fuel filters are should both be replaced
   / Any MF 165 owners....need some help #15
View attachment 357200 ok oil filter canister?
I think so... Its been 5+ years since he sold that tractor and more since I wrenched on it, but I am fairly certain that the fuel filters were both the same shape and the filters might have even been interchangable.
Aaron Z
   / Any MF 165 owners....need some help #16
I believe that they were on his tractor (which had a 50ish HP Perkins Diesel), but as I said, its been a while.
Aaron Z
so Aaron when I replace the filter with the bowl, I take it apart and do I pour out liquid out of bowl. or leave it full ?.. is it diesel in the bowl?
   / Any MF 165 owners....need some help #18
Its diesel in the bowl and I would pour it out. I don't remember if the bottom comes off of the bowl or not (ie: is the "bowl" just a "ring" that the bottom seals against. If it doesn't come off, I would refill it. If it does, I would let the fuel system refill it after you button things back up.
Aaron Z
Thanks Masseywrench and aaron for all your help....Masseywrench I put some photos up,,,it took me some time to figure it out, but with yalls help I think im getting it, and yes I did order a manuel ,,,, thanks again u really help,,, I cant get anyone to work on it due to the location of the tractor...I will just have to learn and do it myself.
   / Any MF 165 owners....need some help #20
Here is someone changing the fuel filters on a MF 35 Deluxe. IIRC, the procedure was the same on Dad's tractor:
Aaron Z
2021 HITACHI ZAXIS 35U EXCAVATOR (A51242)
2021 HITACHI ZAXIS...
2018 Dodge Charger Sedan (A50324)
2018 Dodge Charger...
John Deere TX 4x2 Utility Gator (A49346)
John Deere TX 4x2...
2017 Freightliner Cascadia 125 Single Axle Sleeper Cab Truck Tractor (A50323)
2017 Freightliner...
2018 Infiniti QX30 Premium SUV (A50324)
2018 Infiniti QX30...
2015 Freightliner Cab & Chassis (A47384)
2015 Freightliner...
