Any MF 165 owners....need some help
   / Any MF 165 owners....need some help #12
photo (3).JPG ok oil filter canister?
thanks aaron , so they are both fuel filters are should both be replaced
   / Any MF 165 owners....need some help #15
View attachment 357200 ok oil filter canister?
I think so... Its been 5+ years since he sold that tractor and more since I wrenched on it, but I am fairly certain that the fuel filters were both the same shape and the filters might have even been interchangable.
Aaron Z
   / Any MF 165 owners....need some help #16
I believe that they were on his tractor (which had a 50ish HP Perkins Diesel), but as I said, its been a while.
Aaron Z
so Aaron when I replace the filter with the bowl, I take it apart and do I pour out liquid out of bowl. or leave it full ?.. is it diesel in the bowl?
   / Any MF 165 owners....need some help #18
Its diesel in the bowl and I would pour it out. I don't remember if the bottom comes off of the bowl or not (ie: is the "bowl" just a "ring" that the bottom seals against. If it doesn't come off, I would refill it. If it does, I would let the fuel system refill it after you button things back up.
Aaron Z
Thanks Masseywrench and aaron for all your help....Masseywrench I put some photos up,,,it took me some time to figure it out, but with yalls help I think im getting it, and yes I did order a manuel ,,,, thanks again u really help,,, I cant get anyone to work on it due to the location of the tractor...I will just have to learn and do it myself.
   / Any MF 165 owners....need some help #20
Here is someone changing the fuel filters on a MF 35 Deluxe. IIRC, the procedure was the same on Dad's tractor:
Aaron Z
2007 Jeep Liberty (A50515)
2007 Jeep Liberty...
2016 Poulan Pro PP19A42 42in. Riding Mower (A49346)
2016 Poulan Pro...
2017 FREIGHTLINER CASCADIA 126 SLEEPER TRUCK (A51222)
2017 FREIGHTLINER...
2015 FORD F-150XL SINGLE CAB TRUCK (A51406)
2015 FORD F-150XL...
2016 CATERPILLAR CT660 TRI AXLE DUMP TRUCK (A51222)
2016 CATERPILLAR...
1973 CATERPILLAR 988 LOADER (A51222)
1973 CATERPILLAR...
