m5040
Veteran Member
- Joined
- Nov 23, 2008
- Messages
- 1,023
- Location
- CT
- Tractor
- Kubota M6040 L2250, JohnDeere 310D, Ford 841 Elenco, Ford 961, Trapmaster, PT180 w/LM bucket and 45" brush cutter, PT1430 Deutz w/grapple bucket, Antonio Carraro Tigrecar 6500. John Deere 5300. Former owned Steiner 430 max, Goldoni REV Maxter 7
Over the weekend I went to see a Kubota L45 TLB for sale for a cheap price. On the pre run check, I found the radiator below the tubes, owner said no problem it has enough, he just had a new radiator put in. Test operated the machine, temp gauge came up so figured it was at least up to the sending unit. After I shut it off and opened the radiator cap, it was like letting air out of a tire, then some blackish fluid. After refilling the radiator to top and running the engine, the bubbles wouldn't stop. So it is at best a head gasket or cracked casting.
A friend of mine had the exact same problem on a John Deere 110 and after a head gasket and cyl head, he had to put in a short block, so even know it is a different brand engine, I wonder if the loader backhoe operation tends to over stress the engines on these small backhoes? It was supposedly used by a tree company, so I am sure it was worked to death even know it only had 2700 hours.
Any thoughts?
Any thoughts?
