J_J
Super Star Member
- Joined
- Sep 6, 2003
- Messages
- 18,973
- Location
- JACKSONVILLE, FL
- Tractor
- Power-Trac 1445, KUBOTA B-9200HST
Rip,
Just curious about some things.
Is there any air pressure in a foamed tire? If not, did they punch a hole in the top of the tire to get the foam in and push the air out? Is it possible you could get a flat spot in the tire/foam caused by a sudden fall? Do all your tires have the same outside circumference after putting the foam in? What happens if you put more or less in a tire. Do they put in the same amount of liquid in each tire, or just fill it until it comes out the top of the tire? Do they cut the stem off.
