any alternatives to a conventional grease gun????
   / any alternatives to a conventional grease gun???? #21
I got one of those crappy no name "pit-bull" pneumatic ones from a traveling tool show. I figured I'd try it out and it was only 20 bucks and I could always get a better one if I liked the way it worked. 4 years later I still use it all the time. I'm waiting for it too die so I can get a good name brand one but so far the thing works like a charm. Not many moving parts I guess. :D Air gun is the way to go, I too have not had a cramp in my finger yet!! :)
   / any alternatives to a conventional grease gun???? #22
Pooh_Bear said:
Thanks for the info.
I have a lever action grease gun and I have always hated it.
Takes 3 hands to use the thing. One to hold the gun, one to pump the lever,
and one to hold the hose on the grease zerk. And I always get grease all over everything.
I want something simpler.
Pooh Bear
I had the same problem. For years I struggled with getting the hose on, holding it straight and pumping the grease in. An air grease gun helped, but keeping the hose straigh on the zirk fitting was always a battle.
One day I got to wondering why the grease guns all came with solid tubes along with the flexible ones. I've always been told that the flexible hose is best, and that's all I'd ever used.
Boy was I wrong. The metal tube is a million times easier to use. I have one grease gun with a flexible tube on it for those hard to get to fittings, but for all the others, I use the metal tube. The difference in HUGE!!!!!
Eddie
Yesterday I went to a farm and gin show in Memphis and saw both the lincoln and alamite brand battery powered grease guns. The alamite was approximately $40 more but it was signifcantly lighter and felt better in my hands. I'm going to look at some air operated ones first but the alamite may be what I end up getting.
   / any alternatives to a conventional grease gun???? #24
I have used the lever pump style, the pistol pump style, a Lincoln electric and cheepo Menard pneumatic and paid $12 on sale. They all do the same job. Depends on how often you use it and how much work you want. The lever pump style almost demand a rigid feed tube rather than hose unless you want to be slow and careful. Pistol pump style works good with hose but requires grip strength and gets tiresome for lots of use. Lincoln pnuematic with flexible hose my brother has is the easiest and best but cost $150. Lots of power, runs quite a while and has back up battery. Just need to make sure the back up battery is in charger.
The Menards cheepo actually works just fine for my more limited use after 2 years, except have to drag hose around and limited where it can be use by air compressor. Lots of power set on 100 psi and pumps grease faster than Lincoln electric which is more like conventional grease gun in volume.
   / any alternatives to a conventional grease gun???? #25
I recently purchased the HF air operated grease gun Harbor Freight Tools - Quality Tools at the Lowest Prices and used it last weekend to lube up my L2800 HST and loader. What a difference from my pump up one, especially since I too am currently hand strength limited due to carpal tunnel. I think I paid about $11.00 for it on sale. I notice that they also have several battery operated ones, including the Lincoln that got some air time in this thread.
/Todd
   / any alternatives to a conventional grease gun???? #26
DieselPower said:
There are two different kinds. The single shot is the most common and the cheapest. Lincoln makes a continous cycle one that is much more expensive. I bought one of these a good many years ago when they first came out and I hated it. It only ever seemed to work half the time. Got 2 replacements under warranty and both of them were the same. I just quit using it and went back to the single shot. Later I upgraded to the continous flow cordless battery pack type and have been using nothing but since.
Let me ask you a question... What sort of battery life (per charge) do you get in terms of a full tube of grease? Reason for question, greasing a disc that takes at least a full tube per service. (sometimes 1-1/2 tubes) Would one (or even 2) charged batteries deliver that much service? (I've used air guns but not battery) Looking for something easy to use in the field.
   / any alternatives to a conventional grease gun???? #27
I can probably do 6 to 8 full tubes of grease with the Snap On 18 volt ones that I have. Their what I use in my mobile service trucks.
   / any alternatives to a conventional grease gun???? #28
No one has mentioned hydraulic grease guns. A friend of mine has one and I have been looking for one since I saw his. Works like a hydraulic jack. Requires very little hand pressure and has no hose or battery. He got his from some job he worked on. They must be an industrial gun and not available to the consumer.
David B
   / any alternatives to a conventional grease gun???? #29
This is a timely thread, I just purchased an inexpensive ($20) no-name pneumatic grease gun. The problem I saw on first use (today) was that the tip goes on and off the fitting too easily. The gun will pump grease but, mostly around the fitting, instead of through it. I found it difficult to hold it tight enough on the fitting to actually use it. I ended up using my lever style gun. Since I'm into it for $20 so far, I'll go another couple of bucks and pick up a new tip. The rigid tube on the lever gun works well but, on my backhoe, some of the fittings don't have the clearance and require a flex tube to grease them.
   / any alternatives to a conventional grease gun???? #30
That seems to be a common problem with the cheap gun's, the couplers. Back when I used them I just made sure I got a good Lincoln coupler when I purchased one of these guns.
   / any alternatives to a conventional grease gun???? #31
   / any alternatives to a conventional grease gun???? #32
philbuilt said:
I have a rechargeable grease gun that I bought at Mardens surplus store. It's a one shot per trigger pull. My bh has 47 fittings that is when this gun became priceless. Harbor freight has a simular one. $49.00
phil
Thats where I bought my pneumatic gun. I was looking for the rechargeable one and they were out. You know their commercial, I should have bought it, when I saw it.
   / any alternatives to a conventional grease gun???? #33
Two trains of thought here.
1) Most grease tips can be adjusted to be tighter or more loose. If your new grease tip has a locknut below the the tip it's adjustable.
2) Swap the good tip from your hand gun to the new one.
When adjusting the tips because not to make it too tight or you'll have a REAL hard time getting it off the fitting :D
   / any alternatives to a conventional grease gun???? #34
The tip doesn't appear to be adjustable. I thought of swapping the tip out from the lever gun, but I just ended up using it instead.
   / any alternatives to a conventional grease gun???? #35
I bought a pneumatic Lincoln grease gun from Ohio Tools for about $75. Chose this model because it only needs one trigger pull and it keeps pumping till you let go - easy on the hands
   / any alternatives to a conventional grease gun???? #36
FYI - I just received an email coupon at Harbor Freight for a 12v battery powered grease gun for $44.99 ea.
http://www.harborfreightusa.com/usa/itemdisplay/displayItem.do?itemid=92196
12V RECHARGEABLE GREASE GUN KIT
Up to 6500 PSI for continuous use at a faster rate.
No cord or air hose to get in the way
Rechargeable with one-hour quick charger
Includes 30-1/2'' flex hose with strain relief
Easy squeeze trigger
Comes with 14.5 oz. grease cartridge and carry case
Shipping weight: 10 lbs.
ITEM 92196
thanks for the info everyone. Today I purchaed a lincoln air operated grease gun. I'm looking forward to using it this weekend......did I say that :D
thanks again
-lee-
   / any alternatives to a conventional grease gun???? #38
Didnt some one on here a year or two ago break their arm snatching the hose off a stuck zerk ?
   / any alternatives to a conventional grease gun???? #39
Pat,
It wasn't me that broke my arm, but a couple times it could have been me before I found out that there was an adjustment on the business end of my grease gun. The gun worked fine on all of my fittings except one. I did everything I could think of to get the tip off of the fitting, even tried the claw part of a hammer. I finally gave up and decided to take a couple wrenches and remove the tip. The first turn of the wrench, the tip came right off of the fitting. Learn something new every day.
David B
UNKNOWN  SPOOL TRAILER (A58216)
UNKNOWN SPOOL...
SKID STEER ATTACHMENT HAMMER (A58214)
SKID STEER...
2008 Ford F-250 4x4 Ext. Cab Pickup Truck (A56859)
2008 Ford F-250...
2014 Lamar Pipe Trailer (A60460)
2014 Lamar Pipe...
2004 Mack CV713 Granite Fuel and Lube Truck (A59230)
2004 Mack CV713...
2023 Unverferth 3PT 10 FT Perfecta Field Cultivator (A61307)
2023 Unverferth...
