Anti-Scalp Roller Mod's?
   / Anti-Scalp Roller Mod's? #81
Re: Anti-Scalp Roller Mod\'s?
Your modifications are impressive. The only fly in the ointment that I can see is the sharp edge on the wheel itself cutting into the turf on turns. I believe that is why Kubota built the wheel the way that they did.
What I don't understand is how is the grease going to get from the grease fitting to the inside of the bearing to the axle. I understand that you are filling the cavity, but how will you get sufficient amount of grease between the bronze bushing and the axle itself to keep it properly lubricated? Wouldn't it have been better to put the grease in /forums/images/graemlins/confused.giffrom the center of the axle? I am certain that if I had it in my hand, I could figure it out, but I believe that there is something missing in the pictures. Or.... possibly, it is one of my senior moments in time that is confusing me..... /forums/images/graemlins/blush.gif
Junkman,
Refer to the attached pic.
See the knurled fittings of the hat bushings on either end of the tubular bushing? (2nd hat bushing is not installed because I have to install the wheel 1st before pressing on the 2nd hat bushing). See how the OD of the knurled section is larger than that of the tubular section? The knurled part is what friction-fits into the wheel ID. So, since the tubular part (where the holes are drilled) is smaller dia. than the wheel ID, there is a ~1/8" doughnut void that is formed. The
grease fitting will supply grease to this doughnut area. Once the doughnut is full of grease, additional pumps of the grease gun will force grease through the holes drilled into the tubular shaped bushing....where the axle is located.
With a little luck, as the wheel bearing area heats up during use, the grease in the doughnut area will warm up, expand, and additional grease will be forced through the drilled holes into the axle area.
I e-mailed Moweraxle a while ago to see if he would be willing to make me up some 3/4" axles so that this installation will become a piece of cake. Will update later.
I agree about the rounded wheels issue. The vendor could not come up with the ultimate wheel resin composition that is in the rounded form. He explained that there is a little bit of radius that should help a little with side-ways slippage. Also, the 'flat-sided' wheels are natually much more stronger since they have not been hollowed out like the OEM's. Lastly, the vendor spec'd out 3/4" axles that could take any additional abuse from 'catching' in sideways motion. The vendor and I discussed this in length before I agreed to try this flat-sided, minimal tread radius wheel. I feel comfortable that this is not going to be an issue....but proof's in the pudding come mowing season!
r
Junkman,
Missed part your comment about the square-edged wheel 'cutting' into the turf on the ground.
My assumption has been that this wheel will not be riding on the ground. It can be placed a little lower than the OEM spec's, but not completely down to the ground.
I had always assumed the roundness of the OEM wheels was more for prevention of 'catching' on roots and such when making a sharp turn.
I don't think these wheels will cause a turf cutting problem....can hardly wait 'til mowing season to find out!
   / Anti-Scalp Roller Mod's? #84
As I said in my previous post.....been there, done that. I tried steel hub, rubber wheels, phenolic wheels, and finally, plastic hub with rounded rubber tire and stainless steel roller bearings.
I've used the plastic hub, rounded rubber tire, stainless steel roller bearing wheels now for a year and a half. They are holding up fine....a little grass stained and maybe some dog doooo, but other than that, they have been great....and yes, I run them on the ground all the time. They don't have grease zerks, but I packed the bearings at the beginning of the mowing season and they just keep on rolling.
I tested the steel wheel, rubber tire combination, however the tire was more flat with squared corners and the corners or edges seemed to take a lot of abuse from an occasional rock or the edge of the sidewalk, etc. The phenolic wheels are also succeptible to chipping, gouging, breaking the edge of the wheel.
It has been my experience that the plastic hubbed rounded rubber wheel combination has been a very good solution. I would think that with the addition of a drilled and tapped axle this would be the answer the the anti-scalp wheel solution.
Attached is a picture of the plastic/rubber wheel. They also have an aluminum hubbed wheel with rubber tire with grease zerk and stainless steel bearings. The only fault of the aluminum wheel is the flat tread and squarish edges....as stated eariler, the edges tend to take a lot of abuse.
As for me....I'm going to stick to the gray rubber wheels. After a year and a half there are still no gouges, nicks, etc. A little stained, but they are still round and roll nice and quite when crossing paved areas and have given me absolutely no problems.
I think I've got an extra set....maybe I could send them to moweraxle to look at and see if he can work some magic to come up with a drilled and tapped axle for these things.
   / Anti-Scalp Roller Mod's? #85
The attachment didn't attach /forums/images/graemlins/confused.gif, I'll try again!
   / Anti-Scalp Roller Mod's? #87
DannyWilliams,
Looks like three times the charm /forums/images/graemlins/smile.gif I could view the attachment just fine.
What are the dimensions of your wheels?
Looks good,
Michael
   / Anti-Scalp Roller Mod's? #88
went to a foundry today and they are going to cast one wheel for me with no axle hole and we can check the shrinkage for one thing the wieght because that's how they charge for the wheel. It will look just like the OEM wheel and I will have it by the weekend so I can machine on it and install bronze bushings just like the plastic wheels and I may be able to figure out a price, may not be to bad. If this works these wheels will last forever
   / Anti-Scalp Roller Mod's? #89
I purchased a Cub Cadet Model # 2084 Garden Tractor approximately 11 years ago and the anti-scalp wheels on the deck are equipped with bronze bushings. Looks like they were ahead of their time on recognizing this problem. I just replaced the bushings on the front two anti-scalp rollers. Cub used to make good equipment. I sure hate they sold out to MTD.
Danny,
Would you e-mail Castercity (Sales@Castercity.com) and repeat what you said in your post about your success with the rubber wheel? Address e-mail 'Attention Owen'.
The rubber wheel that you have was my first choce too, but I was afraid it could not stand the abuse....maybe I was wrong.
I also had your concern that the square edged wheel would take additional abuse....but decided to try it anyway...no data at the time of purchase. I'm hoping that these fiber-reinforced wheels will be much more resistant to chipping....that's what the ground up canvas in the resin is supposed to help with. If I remember correctly, the wheels I have are 850lb rated wheels.
Looks like we have several designs that are in testing now or starting soon...
- OEM wheels fitted with sleeves and/or grease fittings
- Danny's rubber wheel
- Roger's canvas fiber reinforced resin wheel, brass sleeves, grease fittings
- Larry's cast iron wheel (coming soon from a foundary near you) and various modifications of the OEM wheel.
- who knows what else may be out there in field testing?
Maybe we should all get together and open a 'Wheels r Us' store? /forums/images/graemlins/grin.gif
r
   / Anti-Scalp Roller Mod's? #91
I wonder if anyone from Kubota ever reads this forum. If they did, we might see some improvements in the products. I believe that Kubota makes a good product, but sometimes lets down the ball on things that they don't have much experience with, such as mowers. I don't know how much grass there is in Japan, but I know that it isn't as much as we have in the US.
   / Anti-Scalp Roller Mod's? #92
Roger,
Message has been sent.
Danny @ "We Bee Wheels" /forums/images/graemlins/grin.gif
   / Anti-Scalp Roller Mod's? #93
Please update me on the latest info for finding a really good replacement anti scalp roller for Kubota mower deck on BX 2230. I have read of several good approaches to the problem but do not have the latest info or contacts for obtaining quality anti scalp rollers for Kubota mower deck. /forums/images/graemlins/smile.gif
   / Anti-Scalp Roller Mod's? #94
Please tell me the latest status of finding and obtaining a qualityreplacement anti scalp roller for the Kubota mower deck. I need some now.
Thank you for any help you can provide.
   / Anti-Scalp Roller Mod's? #95
I had mine modified by Larry at MowerAxle and they work great. I strongly reccommend his modification and you can't beat his good service and speed of turn around from the time that he receives the wheels.... contact him using this e mail address... larry@moweraxle.com
   / Anti-Scalp Roller Mod's? #96
Junkman,
Thanks for your reply. Please tell me what rollers you sent to Larry at MowerAxle for modification. Did he modify your factory plastic rollers, or did you get hold of some other type rollers for him to modify?
Thank you.
charliesmythe@cafes.net
   / Anti-Scalp Roller Mod's? #97
factory plastic rollers were modified. I even used GM grease in them so you might say that I modified them further. /forums/images/graemlins/grin.gif /forums/images/graemlins/grin.gif
   / Anti-Scalp Roller Mod's? #98
Junkman,
Please tell me if you run your 'Modified' factory plastic anti scalp rollers on the ground. If so, do they hold up and last for a year or so without breaking down? Do you know or believe that the rubber rollers from Danny Williams on this thread would be a better value?
Please give me your opinoin as to what is the best solution for the troublesome Kubota factory anti scalp rollers..
Thank you.
   / Anti-Scalp Roller Mod's? #99
I don't run the wheels on the ground, because that isn't the intended purpose of them. I can't tell you how long they are going to last, because the modification is new and I have only been mowing for a month so far this year. Be glad to tell you my experience this time next year if you remember to ask.. /forums/images/graemlins/grin.gif /forums/images/graemlins/grin.gif I don't know if Danny's wheels are going to represent a better value or system for the BX. I believe that only time will tell which is going to be the best system and the least expensive. A lot of people have had the modification done by Larry, so there should be some feedback by the middle of the summer. All that I can say is that I am satisfied with mine at present and the service that I received from Larry was superb.
I've been away for a while...new job (same company), busy life, the usual excuses.
Wanted to give a quick update... My version of the modified deck wheels is working great so far. No wear, no tear, no chipping. And they have taken some torture too.
If I remember correctly, the cost to go to my version is ~$80.
See page 9 of this discussion to see pics and details I posted a while back.
If anybody is interested in ordering this setup, let me know and I'll try to dig up the part numbers to order form Castercity.com.
RET
(38) 8" - 11'L X 20" - 34" FLOOR TRUSSES (A60432)
(38) 8" - 11'L X...
2018 CATERPILLAR 323 EXCAVATOR (A60429)
2018 CATERPILLAR...
INGERSOLL RAND G25 GENERATOR (A58216)
INGERSOLL RAND G25...
2018 Deere 323E (A53317)
2018 Deere 323E...
Booster Cables (A59230)
Booster Cables...
2019 KUBOTA SVL75-2 SKID STEER (A60429)
2019 KUBOTA...
