Another toothbar question.
/ Another toothbar question. #1
MDM
Platinum Member
East Ohio
Kubota L2800HST
Sorry, but I didn't want to hijack someone's thread. I'm going to order a Markham for my 2800 463 loader. The inside dimension is 58 3/8". Will I be alright with the standard amount of teeth or should I have him add 1 or 2 more? I will be doing minor digging and popping out some briars. Thanks again guys.
/ Another toothbar question. #2
NOT ANOTHER ONE!!!;) :D
I never even considered adding some teeth. I'm sure you could have it custom built if you wanted to but I don't think it would be necessary. Plus it would probably cost more. They would have to be more closely spaced. It may not be possible logistically. I don't know exactly how Markham constructs their toothbars but they MAY have stock sections of bar with standard spacing of teeth and just cut off the right amount. But I kinda doubt that. If that's the case you would have to pay a LOT extra for extra teeth. I just wouldn't do it. Mine measured 70.5" inside diameter and I have 7 teeth. You would likely have six and that would be plenty I would think. Besides, if you add extra the spacing would make it look kinda funny I think.
/ Another toothbar question. #3
You will have either 6 or 7 teeth. Call them ask see what they consider standard, then tell them what you want when you order it and they will build it for you, at an extra cost of course. In my opinion, one extra tooth is not going to make any kind of difference.
My 60" bucket has 7 teeth and it is not a Markham.
/ Another toothbar question. #4
Another thing you might want to consider other than the number of teeth is the thickness of the shanks for the teeth. Some are made from inch shanks, others from inch and a half shanks. They should be case hardened steel shanks and the teeth should be forged.
Are there 1/2" drill bits that will fit in a 3/8" chuck? Both my drills are 3/8" chuck. I going to order a Marham bar tomorrow and want to be prepared when it gets here. I wonder if a 1/2" bi-metal hole saw type bit would be able to get through that hardened steel?
/ Another toothbar question. #6
The bi-metal hole saw (the white one) is the easiest and cheapest way to drill the bolt holes. The buckets are nothing more than 3/16" mild steel (buckets are not hardened at all) and the bi-metal hole saw will go thru it like a hot knife thru butter. That's what I used.
Thanks Mad. You are always heplful and I appreciate it.
/ Another toothbar question. #8
MDM,
Searching threads today for a tooth bar and came across this one. Since we have the same toys, was just following up to see if you ordered your bar yet? Come in? Got it on?
Where do I go to order? Is it Markham Welding - Home
/ Another toothbar question. #9
You can get a lot of information from the Markham Welding website. But when you actually come down to ordering you need to call. I'll bet I had exchanged something like two dozen e-mails with Melissa before ordering. It's actually a good thing to be required to call. I think it keeps a closer working relationship between customer and seller. Go ahead and call, Melissa will hook you up with one. The shipping, for overnight freight, was surprisingly cheap as well. I think a toothbar is the best bang-for-the-buck accessory you can get for your tractor. I couldn't imagine not having one now. The only reason I wouldn't get one would be if all I were doing with my loader is moving grain and mulch. With any digging it is more than useful.
/ Another toothbar question. #11
Glowplug, you must have had alot of questions...:)
KarolinaKubota, give her a call and give her your inside bucket measurment and payment method and in 7-10 days it will be at your doorstep or gate entrance.
Installation is easy and if you have a welder you can weld the little doublers they send ya, I added a shim on the toothbar so it would fit a little tighter.
/ Another toothbar question. #12
wushaw said:
...payment method
Thanks wushaw!
Speaking of "payment", I probably overlooked it in the threads while surfing, but what's the average cost of these? I'm thinking I'll end up in the 58" +/- length... I only ask because I know Mrs. K-Kubota will ask me!
/ Another toothbar question. #13
Mine was between 250 - 300, I just can't remember the exact amt. and it will be the same size as yours since we have the same tractor/FEL.
/ Another toothbar question. #14
Thanks wushaw! That is a great price for what I understand I would be getting! Will call today!
Michael
Just got my tracking number. Mine will be here tomorrow.
/ Another toothbar question. #16
I am SOOOOOO slack (and slammed!) but finally ordered my toothbar TODAY. Sheesh...
$254 including delivery! WOW! Spoke with Barbara at Markham and she said they would try to get it out today! THAT is impressive!!
I'm sure I'll be searching and posting for questions/info once I get it. Can't wait!
Michael
/ Another toothbar question. #17
wushaw said:
... if you have a welder you can weld the little doublers they send ya ...
By "doublers" I take it you mean the caps on the end of the teeth? I wouldn't mind having some for my ATI TB. Do you know if you can buy them separate?
/ Another toothbar question. #18
The "doublers" are 2x2x ~3/8" predrilled sqaures you weld onto the outside of the bucket to reinforce the mounting hole.
/ Another toothbar question. #19
Add 1 tooth.
/ Another toothbar question. #20
WOW!!!
Just got a voicemail from Barbara at Markham and my toothbar should be here TODAY!!!
I figured living just several hours away would help speed things up but I never imagined I would order it yesterday and get it today!!!
And again I say - WOW!
2019 CATERPILLAR M316F MOBILE EXCAVATOR (A63276)
2019 CATERPILLAR...
2004 TOYOTA7F GU26 FORK LIFT (A59914)
2004 TOYOTA7F GU26...
Manure Spreader (A65640)
Manure Spreader...
Skeleton Backing Plate (A62679)
Skeleton Backing...
2016 Ram 2500 6.4L HEMI (A62679)
2016 Ram 2500 6.4L...
1974 Transtar 4300 Roll Back Truck (A65563)
1974 Transtar 4300...
