Another propane (fireplace) question....
/ Another propane (fireplace) question.... #1
Richard
Super Member
Knoxville, TN
International 1066 Full sized JCB Loader/Backhoe and a John Deere 430 to mow with
I guess with the turn of the weather, staying warm is higher on my mind.
I have noticed what seems to be trend and am curious if I have a budding issue.
About a year ago, we had a ventless fireplace installed. I have a dual manifold outside where I keep a 100 pound tank attached (as backup) and sitting on a stand, I have a 30 pound tank that use day to day. I use he 30 pound tanks (rotate through three of them) because they are easier to move than the 100 pound tank.
Anyways, here seems to be the problem:
As of yesterday, I have a freshly filled 100 pound AND 30 pound tank attached to the switching manifold. I had the 100 pound tank selected. Pilot lights & stay lit. I turn the fire on an it seems to sputter and go out (including the pilot). Tried 15 times and every time it goes out
I got it burning again, went outside & activated the 30 pound tank. Came back in and the fireplace works 100% fine.
Can the 100 pound tank cause an issue by being too full? (I know it all goes through a regulator)
I had this SAME thing happen when I used my PRIOR 100 pound tank. The problem seemed to go away after I blew some propane off. (literally... I disconnected the connection and opened the valve for 2-3 seconds)
Why might the large tanks be creating an issue?
Well.... interesting.
An update already.
I went to a second fireplace, it did same thing. Pilot light worked....but flames sputtered and all went out when I turned it on.
I went outside, disconnected large tank, purged it for a second and now (knocking on wood) the fireplace is working fine.
I'm beginning to guess that I might have had some air mixed in there that wasn't purged when the tank was filled?
/ Another propane (fireplace) question.... #3
Tanks can be too full. 80% full is the general limit. There needs to be enough space for the liquid propane to expand (boil) into a gaseous state. The gas is what is drawn off and burned in the appliance. Outdoor temperature affects this too but I don't think you would have that problem in Knoxville.
Too full maybe, does each tank have its own pressure regulator?
/ Another propane (fireplace) question.... #4
You could have residual air in the line from them being disconnected while refueling.
2016 Peterbilt 579 (A60462)
2016 Peterbilt 579...
2014 SKYTRAK 10054 TELEHANDLER (A58214)
2014 SKYTRAK 10054...
CFG QK16R (A60463)
CFG QK16R (A60463)
2008 IC Corporation PB105 School Bus (A60352)
2008 IC...
Butler MFG Water Tanker (A61307)
Butler MFG Water...
2010 CATERPILLAR 320DL RR EXCAVATOR (A60429)
2010 CATERPILLAR...
