Carl_NH
Elite Member
- Joined
- Apr 5, 2002
- Messages
- 3,920
- Location
- Coastal NH
- Tractor
- 01 Kubota B21TLB, 2010 Ferris 52" ZTR, Cub Cadet 1811, Gravely Super8
Appears you are in Maine, and have lots of rocks like we do here in NH. Consider getting a full sized used BH 4WD - Case 580, JD 410, Cat 416, Ford 575 or similar - they are 14-16K lbs so can move trees and rocks. They can be found with 3000 hrs for $25-35K then spend the other $30K on a decent used excavator with a blade and a thumb - minimum 10K but a 12K pound class is better.
Neither machine will dig 24-36" stumps quickly but will get the job done. Also your plan for a road - definitely clear at least 30-40 feet wide for your driveway - as trees grow back in, and you need to run electric and have enough space for drainage and snow etc.
Then sell the BH once you have your major work done and get a smaller machine for general property maintenance - but keep the excavator.
Yes you will have some repairs to the machines - hoses, Hyd cylinder rebuilds over the course of the project, but that's the nature of older larger machines.
