Another Newbie looking to buy a tractor
   / Another Newbie looking to buy a tractor #11
Appears you are in Maine, and have lots of rocks like we do here in NH. Consider getting a full sized used BH 4WD - Case 580, JD 410, Cat 416, Ford 575 or similar - they are 14-16K lbs so can move trees and rocks. They can be found with 3000 hrs for $25-35K then spend the other $30K on a decent used excavator with a blade and a thumb - minimum 10K but a 12K pound class is better.
Neither machine will dig 24-36" stumps quickly but will get the job done. Also your plan for a road - definitely clear at least 30-40 feet wide for your driveway - as trees grow back in, and you need to run electric and have enough space for drainage and snow etc.
Then sell the BH once you have your major work done and get a smaller machine for general property maintenance - but keep the excavator.
Yes you will have some repairs to the machines - hoses, Hyd cylinder rebuilds over the course of the project, but that's the nature of older larger machines.
   / Another Newbie looking to buy a tractor #12
..or have a local contractor put in the driveway, and get the tractor needed to maintain it and your property. Clearing the laneway is only half the battle as you will likely need some gravel too.
You could do as much as you can easily do on your own schedule, then hire a contractor with a bulldozer to do the really difficult stuff for about $2,500.
   / Another Newbie looking to buy a tractor #13
Pictures would really help. I have a feeling - it's going to take longer than you envision.
Take seriously what Carl_NH says. Your driveway will need to be wide enough and constructed well enough to get large trucks to the build site. Lumber, concrete, power, well, etc. An 800 foot driveway is no small project.
   / Another Newbie looking to buy a tractor #14
I'm looking to clear a 800 foot as the crow flies single car width driveway through a wooded lot. It will be on an incline and is definitely full of rocks which will need to be moved. The things working in my favor is that the road can really take any route as it simply needs to connect to an adjacent road. That point can be the easiest point from the prospective of making the trail. We also have a house nearby that I can stay at. This means it can be slow and steady progress.
I think he could do 800 feet in a summer!
I mean, I guess this makes sense that I haven't seen someone show up to do a complete job with a tractor before. Haha.
I guess I was being overly optimistic about having essentially unlimited time to do the project and not caring about what path it took. I've walked up to their potential build site and there are clearings over 100+ feet. Just not level paths. Maybe that clouded my view that it was going to be simply building over existing fairly cleared stretches and then some technical work in between.
Definitely taking this all into mind. I won't be able to get any pictures as it's about 50mins away. Basically it's standard New England wooded area. Some places dense, other places really wide. My dad had shared where he thought the ideal entrance would be for the driveway and if I had a picture of that, we'd be debating if a subcompact or 25hp tractor could do it. That section is very open. The problem is it's not like that the whole way.
I do know we wouldn't have to worry about power. They'd put in solar with battery storage and have a generator as a backup. They would have a well and a foundation. So Carl_NH is correct about needing to build a solid footing. The width might not need to be that extreme as the existing gravel road is only 20' wide and the road association only clears a small portion beyond (or sometimes not even the full width of the road).
Very good point!
Especially if they'd be hiring heavy equipment to finish up the build site. I don't think they'll have a foundation but would imagine an excavator might be required before pouring the foundation.
   / Another Newbie looking to buy a tractor #18
Ok, so the stumps.... the old farmers will tell you, sometimes it's easier to plow around them. Stumps are a bear, even with full sized construction equipment (I'm not talking JD35 mini hoe and a skid steer, I mean they can be a bear with a 20 ton hoe and a D5). Something like a 50hp tractor can absolutely pull 5" stumps, and if you take a Lot of time, digging, ramping down, wiggle, ramp down more, you probably can get 12" stumps out. I would try to avoid any really large stumps. Anything not directly in the road bed, cut flush, or grind (if you prefer).
On the driveway itself; I recommend a 12 ft wide driveway, cut any trees within 4 ft of the edge of the drive (you can cut those stumps flush). Get any roots bigger than 2-3" out of the subgrade, and make sure water has some place to go. The driving surface will be Highly dependent on your local materials.
Honestly, I would skip the tractor mounted back hoe. For the $6-8k extra, that is probably a rent something for digging. Some people love their back hoes, but they aren't a lot of fun to put on/off, and either A, get left on 100% of the time, taking 75% of the utility from a machine, or B, get put under a pole barn for years.
On trees; if you do Want/Need a stumps removed, it's better to not cut the tree low. Leave it up atleast 4 ft, so there is some leverage to push-pull on. Don't ram stuff, but you won't general tear anything up if you are in medium range and 2wd. If you find you self getting a running start to push (or pull), stop.
HST transmissions are a joy over old hunt and peek gear shifters, but modern Power Shuttles are fantastic (MF 2860M), and offer basically all the convenience.
Your budget sounds very doable, but don't go hog wild on every impliment at once. Get atleast dual rear remotes, and 3rd function, for the grapple. A sump grinder might be more useful than a back hoe.
If there is a lot of small trees to dense brush; look for a used Brown Tree Cutter 6 ft. You think it's a bush hog, but it's a lot more than that, and can take down 6" standing stuff, and turn it to match sticks, just go slow.
   / Another Newbie looking to buy a tractor #19
I did skip over the rock portion, because rocks can range from a small mountain to basket ball sized, or just plain never ending small-medium rocks. They don't make a tractor large enough time deal with sheet rock. If a truck sized rock is really in the way, there are foam injection products that will split it after drilling and injecting. For truck sized rocks, it's often better to detour or pick up the grade of the road to avoid.
I know somebody probably makes a hydralic hammer that mounts on a tractor loader. DONT do it. I've seen 20 ton hoes break welds, and I always recommend Running from used demolition machines.
   / Another Newbie looking to buy a tractor #20
Appreciate the insight. My budget overall (including attachments) would be around $60k financed. Not a lot up front though. If going with either skid steer or excavator, which would you recommend and why? Would the fact that I can pretty much pick any path over 10acres and it can avoid obstacles along the way influence your thinking?
$60k would easily get you both (not new, obviously) If, for some reason, you had to pick just one, I would get the excavator. Putting in a driveway with a backhoe is a giant PITA, especially if we're talking about a backhoe attachment on a tractor. In rocky ground, it's impossible to do it right using a loader bucket. Really though, for what you describe, it would probably make a lot more sense to just hire someone to put in the driveway and prep the site. A contractor with a decent sized excavator (20-40 ton) and dozer will be able to do in a few days what it would take you months or years to do with a tractor, or weeks with a mini excavator and skid steer.
2014 MACK PINNACLE (A55745)
2014 MACK PINNACLE...
5004 (A55851)
5004 (A55851)
2018 Chevrolet Equinox SUV (A56859)
2018 Chevrolet...
2017 Bobcat T770 Compact Track Loader (A55315)
2017 Bobcat T770...
2012 COMPTANK ACID TRANSPORT TRAILER (A55745)
2012 COMPTANK ACID...
2004 EAGER BEAVER 50GSL/3 DETACH TRAILER (A52707)
2004 EAGER BEAVER...
