Another hub death
/ Another hub death #1
Keltic
Cape Breton Island
13 LS 7010C,91 Kubota L4150,Thomas 153S< Can Car C-4,BobCat 35E, BobCat 590,Pete 378 Tandem, Lots of other junk.
Looks like another hub has blown up on the 7010, number 3 in 3yrs.
/ Another hub death #2
I've had both front hubs replaced on my XR4046. Both catastrophic failures several months apart. Hopefully no more issues.
/ Another hub death
This is the same one they replaced last spring, "the new design", starting to wonder.........
/ Another hub death #4
What exactly is the problem you're referring to? Who's 'they' who replaced 'it'?
If 'it' has failed 3 times in 3 years, there must be a contributing factor to the failures; defective part/poor engineering design, etc.
Say more....
/ Another hub death
The dealer has replaced them under warranty, the bearing and seal break and the oil pukes out, the entire front hub unit has been replaced, it certain qualifies as defective, good call.
/ Another hub death #6
Sames side, each side? 3 times replaced under warranty - what conditions lead up to the failure, anything that seems to precede it or just random failure at any time?
/ Another hub death
This is the second time the right hub failed, completely random, the machine is low hrs and well maintained. I use an angle plow in the winter and all I can think is that the hubs can't handle the load. I can't imagine this size tractor is that delicate.
2013 KENWORTH T6 SERIES (INOPERABLE) (A65643)
2013 KENWORTH T6...
2007 JLG 600HJ 60ft 4x4 Articulating Boom Lift (A64553)
2007 JLG 600HJ...
GYRO TRAC GT-25 FORESTRY MULCHER (A65053)
GYRO TRAC GT-25...
2020 TROXELL CONCEPT 130 BBL STEEL VACUUM TRAILER (A63569)
2020 TROXELL...
(3) New 23X8.5-14 SS tires on 6-lug John Deere compact tractor rims, Coal Valley, IL (A65640)
(3) New 23X8.5-14...
2015 Ford Taurus Sedan (A64557)
2015 Ford Taurus...
