Another hub death
/ Another hub death #1
Keltic
Cape Breton Island
13 LS 7010C,91 Kubota L4150,Thomas 153S< Can Car C-4,BobCat 35E, BobCat 590,Pete 378 Tandem, Lots of other junk.
Looks like another hub has blown up on the 7010, number 3 in 3yrs.
/ Another hub death #2
I've had both front hubs replaced on my XR4046. Both catastrophic failures several months apart. Hopefully no more issues.
/ Another hub death
This is the same one they replaced last spring, "the new design", starting to wonder.........
/ Another hub death #4
What exactly is the problem you're referring to? Who's 'they' who replaced 'it'?
If 'it' has failed 3 times in 3 years, there must be a contributing factor to the failures; defective part/poor engineering design, etc.
Say more....
/ Another hub death
The dealer has replaced them under warranty, the bearing and seal break and the oil pukes out, the entire front hub unit has been replaced, it certain qualifies as defective, good call.
/ Another hub death #6
Sames side, each side? 3 times replaced under warranty - what conditions lead up to the failure, anything that seems to precede it or just random failure at any time?
/ Another hub death
This is the second time the right hub failed, completely random, the machine is low hrs and well maintained. I use an angle plow in the winter and all I can think is that the hubs can't handle the load. I can't imagine this size tractor is that delicate.
2019 Ford F250 4x4 Crew Cab Pickup Truck (A64194)
2019 Ford F250 4x4...
2011 FORD F-750 CHEMICAL TRANSPORT TRUCK (A65643)
2011 FORD F-750...
2021 PETERBILT 367 (A65643)
2021 PETERBILT 367...
2019 TAKEUCHI TL12V2 SKID STEER (A65053)
2019 TAKEUCHI...
Landhero LDH-TWP80, Gasoline Water Pump (A62679)
Landhero...
3IN TRANSFER PUMP (A65643)
3IN TRANSFER PUMP...
