Another Grapple Weight Question
/ Another Grapple Weight Question #21
Well for what its worth I have had a 48" Wildkat Economy grapple. I got in on ground floor 9 years ago and paid 700 bucks delivered to Mass. Only issue I ever had was I was trying to "hog out" a buried bolder by opening all the way and digging with teeth while trying to roll back with grapple locked onforward edge of rock I cracked the welds where cylinder is attached to box beam. Cut a couple of 1/4" thick wedges and welded on-end of problem. As my avatar shows you can get a lot of firewood on it Like you, I use it for clearing brush as well as bucking logs. I'll take the weight savings (350lbs) any day vs lost payload with a heavier, wider grapple.
I had the same grapple for 10 ten years on my previous tractor. My BIL bought the tractor tractor and grapple and it still works fine. I a MTL grapple on my current tractor.
/ Another Grapple Weight Question #22
I vote again to go 'narrow' with a grapple to save weight and to go 'sturdy' vs iffy. We can only 'scoop' so much and little stuff falls out anyway. Large logs etc don't care where/how we grab 'em, we're either half-azzed balanced and won't tip/drag regardless. (if >24' long I'm dodging buildings) What we also with back-hoe thumbs can do might only make more sense of what I'm saying.
/ Another Grapple Weight Question #23
The amount of "whatever" you can grab with a 66" grapple vs a 60" grapple will be completely insignificant. It's going to be more about - what it is and your skill level.
Balancing a load on a 66" grapple is no easier than with a 60" grapple.
If I could have purchased the same model in 48" width I would have. About 80% of what I do - picking and moving large rocks and large chunks of pine tree trunk.
/ Another Grapple Weight Question #24
I bought this cheap, junky, no-name grapple off a guy (new) that he bought at a Richie Bros Auction in the states.
I have abused it, wrenched on it with long material and it has suffered zero for breaking or bending.
/ Another Grapple Weight Question #25
Hard to bust a grapple, IMO. Harder to imagine being without one. Good luck finding serious complaints. In Summer I only remove mine to put the other one on. (horizontal gripping jaw or vertical grabbing 'lid') Keep it light, get more done.
32ft Flatbed Equipment Trailer (A64556)
32ft Flatbed...
2009 ALLMAND MAXI-HEAT MH1000 HEATER TRAILER (A67714)
2009 ALLMAND...
2023 Ford Explorer SUV (A66738)
2023 Ford Explorer...
2012 BRENNER TANK PUP TRAILER (A67714)
2012 BRENNER TANK...
2005 CAT 140H MOTOR GRADER (A67714)
2005 CAT 140H...
Heavy Duty Booster Cables (A64557)
Heavy Duty Booster...
