Another confused first timer
/ Another confused first timer #182
Some of the low end John Deere's DO have aluminum rear ends instead of cast iron like most CUTS. The Low end JD's are REALLY low end. Corners cut to meet a price point.
You have to understand how Deere thinks to understand it. It's like they took all the basic elements that make up a tractor eg Weight, Power, Size, Transmission, PTO type and Options and then put it on a chopping block and figured out how to commoditize each of those elements where they would create enough differences between the models to push the consumer up to the next model/trim level. By building the 3E series tractors with an aluminum frame they made it so light that it created a limited range of use types for that tractor which will push a lot of buyers out of that tractor into the much more expensive 3R series tractors. That's why I wrote in another thread about Deere that the choices Deere offers the consumer is just an illusion. Those cheaper options would not work for the vast majority of people out there. You can see what little confidence Deere has in certain options/bells & whistles when you look at how they self sabotaged their 3D tractors with a transmission driven PTO. I think they literally developed that tractor with the intention of not selling any just to use it as a leader item to lure people into the dealerships and do a bait and switch.
/ Another confused first timer #183
A lot of good points. Whenever I look at a package deal, I assume the implements will be the cheapest versions that they can find. That way, when I compare prices, I take the most conservative view. Maybe you get lucky and they have quality implements...to me, that's just gravy. As for the marketing language, you see it everywhere if you look. Think of bleach, they compare themselves to cleaning without bleach rather than to other brands of bleach.
You could try to pin them down by asking for a list of makes/models of implements to be included, in writing.
/ Another confused first timer #184
The main thing if you turn the drive shaft one time and the blades turn two times. Cheap cutters only turn 1 1/2 to 1 because gear reduction costs money. That's why some rear shredders or Bush hogs cut like a mower and some knock it over.
/ Another confused first timer #185
What do you have them do? Repair work?
Lets see....it used to be things I couldn't do myself. Last year it was replacing the engine computer in the John Deere. I did the trouble-shooting and it came down to the computer. That computer is a known trouble point - it's exposed to engine heat and fluids - and tends to go out at about 5000 hrs/10 years. So mine was overdue.
Note that this is a pre-emissions engine with a independent mechanical injectors. Not common rail.
It's only 4 bolts and a connector, but apparently the fuel computer has to be reprogrammed by JD for each machine. The mechanic did all that. $2500 bucks.
Another time he replaced a leaky main suction hose from the hydraulic reservoir to hydraulic pump on that same Deere 310. It's a heavy, nasty job laying under the tractor and I am just getting a bit old for that. $500 bucks. Plus hose, plus 20 gallons Hyd. fluid.
Each time it costs me about $200 for his driving time to my place. I think it is a deal, and he is one real good mechanic. Ex aviation mech.
Do you have a similar dealer service where you are?
rScotty
/ Another confused first timer #186
I agree. Implements are nice to have, most of us TBNers end up with a row of them. When you get right down to it, a tractor without an implement is just a slow and lonely way to drive around.
That's the beauty of the universal 3pt hitch and universal PTO. Implements are almost all 3pt hitch style. And new or old, every 3pt implement made will fit right up to every 3pt on every tractor. BTW, consider upgrading to telescoping arms and rigid side swing limiters (instead of chains) on any 3pt if offered.
Implements tend to look old and beat up quickly from being dragged through the dirt, but they usually outlast tractors and are easily maintained with available parts. Mid-mount mowers might be the exception, but they aren't 3pt. The point being that used 3pt implements needing paint and some straightening are often available at a fraction of the cost of new. So it comes down to how you feel about new vs used.
The point is not to let the implements influence the tractor decision too much.
/ Another confused first timer #187
Interesting. So what you're talking about here is blade tip speed or spindle speed.
/ Another confused first timer #188
rScotty
I have tried to get mobile mechanic service out where I am. That's all I have ever gotten with my forklift but with zero turns and tractors they always want to take them back to their shop claiming that they won't have the part or the necessary tools to do the repair on site or will have to diagnose the problem first and then make the repair. So I am curious how you are handling this?
/ Another confused first timer #189
I will add to this that it also depends on the type of implement and where you live. Flail mowers for example is a type of implement that I would not advise someone like the OP to purchase second hand unless they know what they're getting themselves into and have the tools and skills to make repairs. Depending on where you live, some of these shortline manufacturers may not have a local dealer near you to make repairs if you purchased something used.
/ Another confused first timer #190
Well, I haven't had that problem so I don't know how I would handle it.
Generally since I have to schedule when the mobile unit is to be sent out that means I've already talked with the service manager and between the two of us we've got a pretty good idea of what is going to be involved and if the mobile unit makes sense.
Obviously that requires a service manager who is himself a master mechanic in every way. So again we come down to mobile service being the mark of a professional shop.
The JD mobile truck is pretty well equipped with hundreds of common spares, welding, generator, small crane, hydraulic tester, and computer diagnostics. He usually manages to talk me into some routine maintenance as well. I'm not too hard to convince on that. Nice to have someone else do all the scut work and then clean up and take the old fluids away.
We've had a couple of independent auto mechanics try to start up similar services, but so far none have succeeded. I understand that the RV industry has some successful mobile service trucks in big cities. Never used them, though.
rScotty
2016 Chevrolet Traverse SUV (A59231)
2016 Chevrolet...
2014 Timpte Hopper Bottom (A61307)
2014 Timpte Hopper...
YANMAR VIO35-6A EXCAVATOR (A59823)
YANMAR VIO35-6A...
2014 International WorkStar 7400 Service Truck with Crane, VIN # 1HTWGAAR8EH765283 (A61165)
2014 International...
2015 Vermeer D9X13III Directional Boring Machine (A59228)
2015 Vermeer...
2020 Bobcat MT85 (A53317)
2020 Bobcat MT85...
