Another confused first timer
/ Another confused first timer
Kubota has a similar tractor with only a front bucket for $21k. No canopy/gannon/brush hog
/ Another confused first timer #172
I see in the ad that the box scraper is listed as a "Gannon". FYI, Gannon is a brand. As a general rule most any rear box scraper is refered to as a "Gannon", even though it is not. I have a hard time believing that they would be including a Gannon brand scraper as they are usually the highest price units around. I've sold Gannon, Landpride and Woods along with a few others. More than likely, they will be using an "off" brand. Just my observation.
It's also a regional thing, I think.
I was born and raised in AZ, and we always called box blades "gannons". I never heard them called anything else until I moved up here.
/ Another confused first timer #173
Does the Kubota have the upgraded lights and power inverter? How about the added rear wheel ballast ? Tilt steering? The upgraded air filter? Does it even have the cruise control? You need to make a list and compare.
Slowpoke - Yes, everyone calls it a Gannon around here......
DGZRT - I will check, I don't think so. Kubota seems to think they have become Deere.......
/ Another confused first timer #175
If you are weighing your decision on Dealer Access, and buying new, my experience has been that dealers are a fickle thing. They come and go and, move around. At least they do in my area of Western, Central Oregon. There is no guarantee the dealer you bought from will be there in 5 years. How ever, there will always be a local, non-brand, tractor repair shop. I'm of the opinion, that a used tractor is a better value. Especially if you can be directly involved with the seller and see how the tractor was used. You can quickly tell if a tractor was "trashed" doing too much work, or if it was, that golden, single task tractor, or a rarely used one at an estate sale. You can determine this by looking at all their other stuff, and if the owner is organized, and figuring out the reason for the sale. When you do find one that meets your needs and price point, do an extra step, and hypothetically, start looking on the availability of normally replacecable parts that a repair shop could have assess to. If you start coming up with "unavailable," then this is the reason it is being sold. You can bet the owner already knows this. :)
/ Another confused first timer #176
I've never heard of a box scraper called a "Gannon" unless it was a box scraper made by Gannon - and those are expensive. Maybe calling all scrapers "Gannons" does sometimes happen in other places & other conversations, but not by a dealer and especially not when he is advertising a "special deal".
The advertisement also says:
- Full Independent Four-Wheel Drive (4X4) (not just front wheel assist);
- Unitized FULL STEEL Main-Frame Chassis (not aluminum)
- Live 540 RPM Rear Power Take Off (PTO);
So lets look at those things. See if they are true or what they really mean.
Maybe the Kioti CX2510H does have a fully independent 4x4 and not just front wheel assist. But I wonder if that is really true. If true, it is the only compact tractor on the market to have that feature. All the rest are part time, front wheel assist (no center differential). That includes every other compact tractor I'm aware of.
Steel chassis?? Well that much is probably true, but the implication is that others have an aluminum chassis. And I doubt that. Sure there may be some garden tractors out there with an aluminum engine/transmission/rear end assembly doubling as an integral aluminum frame. But in the real tractor world with highly stressed loaders and 3 pts I've never heard of anything but steel being used for frames. That goes for all compacts and utilities.
"Live PTO"?? Again, probably true but what's not being said is that's the least favored type of PTO, and only one small step better than a transmission driven PTO. You will do much better with a "fully independent PTO". And better yet if the independent PTO has some features like a built in overrunning clutch, brake, and multispeed capability.
That whole advertisement just doesn't feel right to me.
rScotty
rScotty - Good points......What specifically should I ask the guy when he returns my call?
/ Another confused first timer #178
I'd let him do the talking. Frankly the deal sounds pretty good. I was just put off by the exaggerations and hyperbole when I posted above. Why would they say those things if the basic deal is good??
You might tell him that an old mechanic guy you were talking to had those questions (message #177) - or maybe don't bother. We already know the answers & they don't really bother us.
For sure, ask if the dealership offers trailering if warranty service is required (and who pays?) and ask if they have a truck outfitted for mobile mechanical service. A lot of dealers these days have both those services.
From your viewpoint having a service dept. says something about their committment. But the fact is that very few new tractors require any type of in depth warranty work. Most require none. Still, it's nice to have it in writing. I never go to my dealer, but do sometimes call and have his mobile service truck and mechanic come out.
What else? Well, the most important thing I'd ask is what it would take to move from the CX2510H to the CK2610H. From the specs, I believe that would be a sweet upgrade and worth bargaining for.... even if it meant paying more to get. the 2610 has 3 range HST, 50% more lift, more weight, and larger tires...
BTW, if your soil is sandy and not much snow you probably want industrial tires, not lugs. Industrials are R4 tires rather than R1 tires. You may have to add a dollars for that option but worth it and even more so if you have thorns. Now if you have mud instead of sand and gravel....and especially if you have slippery clay-base mud or sloppy snow then R1 is the tire.
Otherwise just let him talk and make you offers.
Good hunting,
rScotty
/ Another confused first timer #179
Some of the low end John Deere's DO have aluminum rear ends instead of cast iron like most CUTS. The Low end JD's are REALLY low end. Corners cut to meet a price point.
/ Another confused first timer #180
rScotty
They're taking a pot shot at Deere's 3E tractors. Those tractors for the most part have aluminum frames to get the weight down. Most have never had issues with them. The few that did were trying to work the tractor beyond it's limits with that type of setup and I guess that's their argument. They're selling maybe a medium duty 25hp compact tractor compared to Deere's light duty 3E series tractors.
It always makes me laugh now when I see stuff like this. It's really ridiculous that the industry is still selling tractors with this antiquated technology. The tractor industry is the only one of it's kind that builds motorized equipment with outdated, antiquated technology and offers them for sale to the public. This is the center piece of their "game" to push you into another model with modern technology. It's backwards thinking.
Takeuchi TB016 (A53317)
Takeuchi TB016...
2011 SOUTHWEST  GOOSENECK (A58214)
2011 SOUTHWEST...
2015 JOHN DEERE 35G EXCAVATOR (A52707)
2015 JOHN DEERE...
2023 Global Trailers GT302 30 Ton 60YD T/A End Dump Trailer (A59230)
2023 Global...
20' SINGLE AXLE INDUSTRIAL TRAILER (A59823)
20' SINGLE AXLE...
2019 John Deere 310L EP Backhoe (A53485)
2019 John Deere...
