angle iron axle
/ angle iron axle #1
shadetree
I want to use a piece of 1/4 x 2 x 2 angle iron for an axle. I cut 2 - 2 inch pieces for the ends. Will bore a hole and attach wheels with a bolt.
What is the best way to align the ends for welding?
/ angle iron axle #2
The angle will only support a hundred pounds or so,,,
why worry about alignment,??, there will be no weight on the tires.
/ angle iron axle
I guess align was the wrong word. I can think of two ways to attach the angle iron to accomplish what I want and was wondering which would be better.
/ angle iron axle #4
So you're using the 2 pieces of angle iron for axle supports, like a wheelbarrow tire? I'd bolt them together with a tubing spacer that's the width of the wheel assembly and tack it where it needs to be, check the alignment again with a square or tape measure, then burn 'em in.
/ angle iron axle #5
Are you saying a 1/4" angle top and a 1/4" angle bottom with stubs sticking out the ends? Might be ok for a Lawn or ATV trailer. How much weight do you hope to haul on this thing.?
/ angle iron axle #6
A picture is worth a 1000 " tell us more" posts.
Sketch something on paper, take a photo, and post it. You'll get some good advice.
Without more information, it will look like this if you do what everyone will suggest. :)
Bruce
/ angle iron axle
I dropped my phone yesterday and it no longer will take pictures. I draw about as well as I write so...
Thanks for trying to help... I can't even explain it to myself. :confused3:
/ angle iron axle #8
Thanks.
I would prefer choice one. Choice two leaves the lower left corner unsupported.
Bruce
/ angle iron axle
Good point. And it will take less grinding to get the top right to fit the rounded corner. Thank you.
/ angle iron axle #10
I also question how much weight you are hoping to haul.
Need more info. How wide is the axle? How big are the tires? How big is the trailer?
I wouldnt trust a 2x2 angle iron axle to hold more than I could lift in a wheel barrow. Angle iron over any kind of span is very weak, and has almost NO torsional rigidity.
/ angle iron axle #12
Without any information other than what you've given us and realizing this is the bare minimum, I'd just weld a piece of shaft in the inside corners of the angle iron and have it stick out far enough to be the axles.
/ angle iron axle
Now that is the ticket. Fits better with my skill level (none) too.
Since I can't post a picture I will try to ease the worry with a few details.
The axles are 18 inches wide
Wheels are 10" HF
Load is 4 x 6 HF band saw
No you will not be meeting me pulling this down the interstate. Will just be going from shed to under my tree.
Thank you all for the help. I'm having one of those days where I can't get out of my own way. But I've been outside in the sun and I'm happy.
/ angle iron axle #14
For inspiration, here's what I do with 10" wheels on my welding carts.
I plug weld the (solid round stock) axle to the inside of square tube.
Terry
/ angle iron axle #15
18" sounds narrow unless it's for ease of storage, as band-saws tend to be top-heavy. Could QA outriggers help at all?
If you mean HFT's pneumatic tires then I'd foam them or expect tip-overs when haulin' 'er out/in.
/ angle iron axle #16
Love them fenders BB !That shop is immaculate . What do you do with all that machinery ? Do you farm , truck , construction ?
/ angle iron axle #17
Thanks! :)
I'm retired from farming and I just putter.
Terry
/ angle iron axle #19
Yes BB, most impressive.
I too like everything mobile. And if not with wheels/castors, with sufficient clearance underneith to get a pump truck under.
/ angle iron axle #20
I am very fortunate to be in a position to dip into my teenage daughter's potential inheritance money.
I think she realizes it is more 'financially advantageous' to let me indulge in my shop activities than put me in one of the sketchy retirement homes she's been threatening me with. :D
Terry
Pallet of Four Pivot Wheels & Tires (A62177)
Pallet of Four...
2024 Freightliner M2 106 Altec DM47B-TR Insulated Digger Derrick Truck (A61573)
2024 Freightliner...
2005 LEDWELL LW40ADC - 40' ALUMINUM FEED TRAILER (A63290)
2005 LEDWELL...
KSI Conveyor (A63688)
2017 Cadillac Federal 70IN Limo w 27466 Miles, Premium Federal Coachwork, Luxury Transport (A63688)
2017 Cadillac...
2024 DODGE RAM 2500 HEAVY DUTY PICKUP TRUCK 4x4 (A59912)
2024 DODGE RAM...
