angle iron axle
/ angle iron axle #1
shadetree
I want to use a piece of 1/4 x 2 x 2 angle iron for an axle. I cut 2 - 2 inch pieces for the ends. Will bore a hole and attach wheels with a bolt.
What is the best way to align the ends for welding?
/ angle iron axle #2
The angle will only support a hundred pounds or so,,,
why worry about alignment,??, there will be no weight on the tires.
/ angle iron axle
I guess align was the wrong word. I can think of two ways to attach the angle iron to accomplish what I want and was wondering which would be better.
/ angle iron axle #4
So you're using the 2 pieces of angle iron for axle supports, like a wheelbarrow tire? I'd bolt them together with a tubing spacer that's the width of the wheel assembly and tack it where it needs to be, check the alignment again with a square or tape measure, then burn 'em in.
/ angle iron axle #5
Are you saying a 1/4" angle top and a 1/4" angle bottom with stubs sticking out the ends? Might be ok for a Lawn or ATV trailer. How much weight do you hope to haul on this thing.?
/ angle iron axle #6
A picture is worth a 1000 " tell us more" posts.
Sketch something on paper, take a photo, and post it. You'll get some good advice.
Without more information, it will look like this if you do what everyone will suggest. :)
Bruce
/ angle iron axle
I dropped my phone yesterday and it no longer will take pictures. I draw about as well as I write so...
Thanks for trying to help... I can't even explain it to myself. :confused3:
/ angle iron axle #8
Thanks.
I would prefer choice one. Choice two leaves the lower left corner unsupported.
Bruce
/ angle iron axle
Good point. And it will take less grinding to get the top right to fit the rounded corner. Thank you.
/ angle iron axle #10
I also question how much weight you are hoping to haul.
Need more info. How wide is the axle? How big are the tires? How big is the trailer?
I wouldnt trust a 2x2 angle iron axle to hold more than I could lift in a wheel barrow. Angle iron over any kind of span is very weak, and has almost NO torsional rigidity.
60'' skid steer bucket (A61567)
60'' skid steer...
2022 FORD F-250 STX CREW CAB TRUCK (A59823)
2022 FORD F-250...
2012 Chevrolet Van (A55973)
2012 Chevrolet Van...
2025 Pabreak Auger Bits and Plate Skid Steer Attachment (A61567)
2025 Pabreak Auger...
Set 4 - 10-16.5 tires on wheels for bobcat (A61567)
Set 4 - 10-16.5...
MANIFOLD TRAILER (A58216)
MANIFOLD TRAILER...
