Andrew Camarata
   / Andrew Camarata #331
Cued to start at the fun part. Watch for the next minute where things go south. He's lucky.
It started from the start. What part is the fun part?
   / Andrew Camarata #333
this is worth watching. First he fixes the winch on his dozer and then uses it to pull an old Subaru Outback literally in half, at the end.
actually quite entertaining.
Nice 5k video, my new monitor supports it and his stuff when focused right on is really good to look at. That drone he uses must be high end for 5k; just glad
he uses it. His stuff defaults to a lower setting but if you have a good monitor, you can go into the menu and pick the highest available. The difference between 1080 and 4k is huge, not sure what 5k does. Probably requires 5G to stream it.
it was nice to see him working on big old equipment again, and taking his time to do it right.
   / Andrew Camarata #334
So that winch was fully hydraulic? he said some stuff in a previous video that confused me or I misheard him.
   / Andrew Camarata #335
I believe he said the winch was PTO driven and the brake and whatever the other control was, is hydraulic.
   / Andrew Camarata #336
The pto drives the hydraulic pump. The pump powers the winch. The pto has a forward, neutral and reverse to change the direction on the cable and allows a neutral position.
   / Andrew Camarata #337
The hysters I believe the gearing is on the hydro side.
   / Andrew Camarata #338
The video is worth watching in its entirety if you're a gearhead.
   / Andrew Camarata #339
Yeah I was curious because I thought he said mechanical with hydraulic controls or something.
   / Andrew Camarata #340
Could be, there might be just an on or off on the pto, but I saw no controls on the hydraulic side. I
watched the whole video. Never worked on a Hyster or a Cat, my experience has been with Komatsu,Dresser,Fiat- Allis and a couple others. Have a good one!
2018 JLG 742 TELESCOPIC FORKLIFT (A52709)
2018 JLG 742...
2014 FORD F-250 (A58214)
2014 FORD F-250...
2021 Chevrolet Silverado 1500 Pickup Truck (A56858)
2021 Chevrolet...
2014 Ford F-150 Pickup Truck (A56858)
2014 Ford F-150...
PORTABLE HAY FEEDER TRAILER (A52708)
PORTABLE HAY...
Kubota K7874 18in Digging Tooth Bucket Excavator Attachment (A55973)
Kubota K7874 18in...
