Amps formula??
/ Amps formula?? #1
dthomas
Newton, Mississippi
New Holland 1720
I would like to figure how many lights I can safely run at one time. What is the formula for figuring amps based on wattage? /w3tcompact/icons/crazy.gif
/ Amps formula?? #3
Voltage times the current. 12w (watts) is equal to 12 volts drawing 1 amp. A 60w light would draw 5 amps.
Keep the greasy side down.
Mike
/ Amps formula?? #5
I'll add an example (I always needed examples to let me see the light (bad pun intended))
if you wanted to add 5 100W bulbs to a 12V system, this would require
500W = 12Volts X XAmps
X amps = 500W / 12 Volts
X = 41.66 Amps
(lets hope that you do not need 5 100 W lights/w3tcompact/icons/smile.gif)
rf33
/w3tcompact/icons/wink.gif
/ Amps formula??
Thanks to everyone for the help. I have already added two 50 watt lights and was wondering about running them and the orignal headlights all at once. Since the alternator is rated at 35 amps, I should be alright. Kevin, thanks for the links. Now I will make a spreadsheet application so I will not forget. /w3tcompact/icons/smile.gif
2024 MACK DUMP TRUCK (A63276)
2024 MACK DUMP...
2021 JOHN DEERE 324L WHEEL LOADER (A65053)
2021 JOHN DEERE...
T/A Flatbed Tag Tailer (A64556)
T/A Flatbed Tag...
2019 HYDREMA MX14 TIER 4 MOBILE EXCAVATOR (A63276)
2019 HYDREMA MX14...
2013 Nissan Pathfinder SUV (A64557)
2013 Nissan...
John Deere 350 Sickle Bar Mower (A66408)
John Deere 350...
