Amps formula??
/ Amps formula?? #1
dthomas
Newton, Mississippi
New Holland 1720
I would like to figure how many lights I can safely run at one time. What is the formula for figuring amps based on wattage? /w3tcompact/icons/crazy.gif
/ Amps formula?? #3
Voltage times the current. 12w (watts) is equal to 12 volts drawing 1 amp. A 60w light would draw 5 amps.
Keep the greasy side down.
Mike
/ Amps formula?? #5
I'll add an example (I always needed examples to let me see the light (bad pun intended))
if you wanted to add 5 100W bulbs to a 12V system, this would require
500W = 12Volts X XAmps
X amps = 500W / 12 Volts
X = 41.66 Amps
(lets hope that you do not need 5 100 W lights/w3tcompact/icons/smile.gif)
rf33
/w3tcompact/icons/wink.gif
/ Amps formula??
Thanks to everyone for the help. I have already added two 50 watt lights and was wondering about running them and the orignal headlights all at once. Since the alternator is rated at 35 amps, I should be alright. Kevin, thanks for the links. Now I will make a spreadsheet application so I will not forget. /w3tcompact/icons/smile.gif
2019 HYDREMA MX18 TIER 4 MOBILE EXCAVATOR (A63276)
2019 HYDREMA MX18...
2010 PETERBILT 384 (A65643)
2010 PETERBILT 384...
Log Grapple (A65640)
Kivel Skid Steer Forks (A65640)
Kivel Skid Steer...
Case 2090 Tractor (A66285)
Case 2090 Tractor...
Wolverine MCB-11-48W Mini Skid Steer Bucket (A62679)
Wolverine...
