Amp Gauge Question
/ Amp Gauge Question #1
SandburRanch
NHtd75
This old tractor amp gauge looks old enough to be 6 volt and it isn't marked. Are amp gauges volt specific? If it came from a 6 V system would it destroy it to test it with a 12 V system?
/ Amp Gauge Question #4
It will certainly work on either, but voltmeters, which have several advantages over ammeters have been more highly recommended for decades.
No high amperage wires run through the dashboard with a voltmeter, and best of all, a voltmeter actually shows you the current status of your battery rather than just showing whether it is charging or discharging at the current moment.
A voltmeter can be used for troubleshooting far more effectively than an ammeter.
/ Amp Gauge Question #5
Okay, I agree about the volt meter but, I'm thinking a person can kinda tell if all the glo plugs are working with the amp meter. bjr
/ Amp Gauge Question #6
I think both would be ideal. It is nice to see how much charge your battery is drawing to get an idea if it is low in charge.
/ Amp Gauge Question #7
Just going off topic....
"Modern" cars and trucks have a standard connector (OBD II port, since about 1996) for diagnostic trouble codes.
Is there something similar on (relatively recent) cat 1 and 2 tractors ?
This thread stimulated the thought that I could use a scan-gauge or similar multiple gauge to read out much more than just volts - as I do in my truck.
JOHN DEERE 5100 TRACTOR (A63291)
JOHN DEERE 5100...
2025 SDLANCH IRGC40 Two-Seat Electric Tricycle (A64194)
2025 SDLANCH...
2017 Chevrolet Silverado Z71 (A64127)
2017 Chevrolet...
2021 BOBCAT T870 SKID STEER (A62129)
2021 BOBCAT T870...
2020 GMC AT4 CREW CAB TRUCK (A60430)
2020 GMC AT4 CREW...
JLG E300AJ (A60462)
JLG E300AJ (A60462)
