Amp Gauge Question
/ Amp Gauge Question #1
SandburRanch
NHtd75
This old tractor amp gauge looks old enough to be 6 volt and it isn't marked. Are amp gauges volt specific? If it came from a 6 V system would it destroy it to test it with a 12 V system?
/ Amp Gauge Question #4
It will certainly work on either, but voltmeters, which have several advantages over ammeters have been more highly recommended for decades.
No high amperage wires run through the dashboard with a voltmeter, and best of all, a voltmeter actually shows you the current status of your battery rather than just showing whether it is charging or discharging at the current moment.
A voltmeter can be used for troubleshooting far more effectively than an ammeter.
/ Amp Gauge Question #5
Okay, I agree about the volt meter but, I'm thinking a person can kinda tell if all the glo plugs are working with the amp meter. bjr
/ Amp Gauge Question #6
I think both would be ideal. It is nice to see how much charge your battery is drawing to get an idea if it is low in charge.
/ Amp Gauge Question #7
Just going off topic....
"Modern" cars and trucks have a standard connector (OBD II port, since about 1996) for diagnostic trouble codes.
Is there something similar on (relatively recent) cat 1 and 2 tractors ?
This thread stimulated the thought that I could use a scan-gauge or similar multiple gauge to read out much more than just volts - as I do in my truck.
2012 Kubota RTV 1140 4x4 Diesel Utility Cart (A61567)
2012 Kubota RTV...
UNUSED MINI HYD AUGER SET (A62130)
UNUSED MINI HYD...
UNUSED KJ 45'X25' DBL GARAGE STEEL BARN SHED (A62131)
UNUSED KJ 45'X25'...
2017 Kubota M7-151 Premium MFWD Tractor (A61307)
2017 Kubota M7-151...
2017 Ford Escape SUV (A61569)
2017 Ford Escape...
2007 CATERPILLAR 725 OFF ROAD DUMP TRUCK (A60429)
2007 CATERPILLAR...
