Air Pressure Question
/ Air Pressure Question #1
poman
Bonham, TX - Fannin County
NH TC33D
I have spent the last hour looking for a post I remember seeing which included a suggestion for R4 tire pressure when mowing. The subject had to do with mowing and leaving the least amount of trails or impressions in the ground. I was unable to find that post. /forums/images/graemlins/frown.gif/forums/images/graemlins/confused.gif Can someone help me out with this information, please. /forums/images/graemlins/smile.gif
Thanks
poman
/ Air Pressure Question #3
I remember the post and am waiting to try it also as I have R4's. I think in a nut shell you are to run your tires on the lower range of what your manufacture tells you to.
murph
/ Air Pressure Question #4
I did some experimenting last Summer, and went as low as 7#. This was OK for mowing, but when I was bush-hogging in some rough stuff and got the mower hung up, I spun a rear tire on the rim and leaked some fluid. I run more air in the fronts when using the FEL, due to the weight. It looks like something around 10-12# may be the lower limit on my B7500 for general use. The tires are rated for much more than that as a maximum inflation, but the R4's tend to feel like solid steel tires when you really blow them up..................chim
/ Air Pressure Question #5
I haven't check the pressure in my R4's yet but they are hard as a rock so I am assuming they are at the maximum. I will let them down to 12 this summer for mowing.
murph
Ford 3930 Tractor (A65579)
Ford 3930 Tractor...
2016 Chevrolet Silverado 4x4 Crew Cab Pickup Truck (A64194)
2016 Chevrolet...
2007 PETERBILT 386 (A65643)
2007 PETERBILT 386...
New/Unused ATS Grass Proof Cloth (A65583)
New/Unused ATS...
2006 Hypac C530AH Pneumatic Wheel Compactor (A64553)
2006 Hypac C530AH...
2009 Chevrolet Silverado 2500 Crew Cab Pickup Truck (A64556)
2009 Chevrolet...
