Air Compressor WARNING!
/ Air Compressor WARNING! #111
Compressor Question. I fixed my buddies dewalt compressor. It needed the pressure switch and i rebuilt the control valve, easy peasy.
It runs fine, gets up to about 200 lbs and shuts off. I have drained it.
If it just lays there, unused, about how long should it go before it cycles back on. I'm not sure but, i might have a leak.
I will go back and look but I'm curious , what is normal?
thx
Hours if not days.
Depends on how leakproof it is.
Aaron Z
/ Air Compressor WARNING! #112
Very timely, I just rewired and old compressor that could hold over 200 psi... once I got it cranked up, it popped a hole in the bottom (very low pressure). This tank sat in my basement for a long time (to be fixed). Finally got around to it and the hole happened... first thought was... it's cast iron, weld or braze?
Looking for a donor tank at the moment...
I tried a tank repair experiment.
First: Put some OSPHO in the tank, and sloshed it around a bit, and let it sit for several days.
Then drained the OSPHO, and hooked the blower end of a vacuum to the tank with all tank fittings removed.
When I believed it to be dry, added a wet mix of two part marine epoxy to the tank, allowing the epoxy to lay in the bottom.
Waited a week,
Process worked.
The tank is still in use 5 years later
/ Air Compressor WARNING! #113
/ Air Compressor WARNING! #114
Doesn't say, although the barrel had held waste oil and gasoline at some point
. and an update said the barrel contained a small amount of liquid.
Sounds like he didn't take any precautions at all . Lit the torch and pierced the top with an Oxy / Acetylene torch...
Bet he never does that again.
/ Air Compressor WARNING! #115
When you see the result of the valve on a large Oxygen cylinder break off; changes you perspective fast. when I went to welding shop at high school we had to change out cylinders on the manifold. Kid moved a full cylinder w/o the cap on. Lost control and it became a rocket. Went through a reinforced concrete block wall and destroyed the door on a parked car 20 feet away. Lucky he was behind it.
Ron
/ Air Compressor WARNING! #116
Hours if not days.
Aaron Z
Thx, that's what i thought. i fixed my friends but it only goes 1 hour before recycling, if left alone. i think i better rewrap all his old connections. better than nothing!
/ Air Compressor WARNING! #117
My compressor hardly loses air at all. What I did was buy quarter turn valves and install then by the quick couplers. That has saved considerable compressor cycling. I basically don't hear the compressor run unless I use air.
My compressor serves Five buildings. Every coupler has a small quarter turn valve. The losses otherwise would be unacceptable. Not to mention, once in a while an air hose blows which could leave the compressor running.
/ Air Compressor WARNING! #119
Good comment - more to see and learn here than everything else combined
/ Air Compressor WARNING! #120
An old spray bottle with a little dish soap and water sprayed on the connections after it pumps up should find any leaks.
Cummins 6-Cylinder Diesel Engine with Transmission (A59230)
Cummins 6-Cylinder...
2014 Ram 1500 4x4 Crew Cab Pickup Truck (A59230)
2014 Ram 1500 4x4...
WOOD GRABBER FOR MINI EXCAVATOR (A58214)
WOOD GRABBER FOR...
Dayton 32965 80-Gallon Horizontal Air Compressor, 22 Volts, 5 HP, 2 Stage, 3 Phase (A59076)
Dayton 32965...
Hilti TE 2000-AVR Electric Jack Hammer (A60352)
Hilti TE 2000-AVR...
2004 VOLVO VHD TRI AXLE CEMENT MIXER (A59906)
2004 VOLVO VHD TRI...
