Air Compressor Troubleshooting
/ Air Compressor Troubleshooting #21
at work we did that. had an old upright 60g comp that gave out, got a new upright with it's own 60g tank, but old pump was 2 stage and higher SCFM than the new one which was single stage :( . we junked the old comp, and chained the tanks together and let it air in the morning. PLENTY of air even when using the 1" gun to change tires on the 16 wheeler..
soundguy
/ Air Compressor Troubleshooting #22
That 90 PSI and scfm rating on the tool is minimum air needed to run the tool, not maximum.
Actually they'll work, to some extent, on lower pressure. The 90 psi is the pressure at which they are rated, and if the tool should break and they could prove you were running higher pressure, they could deny warranty coverage. But I've never known of that happening.
/ Air Compressor Troubleshooting #23
For reference, HP ratings on compressors are often deceiving. A better indicator of the true HP of a compressor is the amps on the motor. A 3 HP, 230V motor pulls 15 amps, a 5 HP 23 amps. A 2 HP, 115V motor should pull 20 amps. If not, you are not getting a full 2 HP. A typical 3 HP compressor puts out about 9.5 CFM@ 125 PSI or 10.5 at 90 PSI. Sounds like your compressor is closer to a 1.5 HP, for what it's worth.
/ Air Compressor Troubleshooting #24
yep.. alot of places list 'peak' hp.. :)
kind of like lawnmower hp ratings. it's the number tested, with top fuel, and no accessories onthe engine.. and max rpm, just befor ethe head flies off.. then they stamp that onthe engine as it's rating.. ;)
soundguy
No doubt. How can I compare labeled output against ideal about as you are saying? Is there an equation or rule of thumb?
/ Air Compressor Troubleshooting #26
I got recently got a regulator and filter combo from TSC it's a Cambell...it seems to work fine...no issues with any of my tools
/ Air Compressor Troubleshooting #27
The easiest way to check what it is doing is to check the amp draw when it is running under load, and compare to the values I gave you above.
2009 Kubota RTV1140 (A57148)
2009 Kubota...
2015 Freightliner M2 106 AWD Altec DM478BTR Insulated Digger Derrick Truck (A60460)
2015 Freightliner...
(APPROX. 20) 4' X 8' X 3/8" SHEETING (A52706)
(APPROX. 20) 4' X...
2019 Deere 550K (A53317)
2019 Deere 550K...
2000 ITASCA SUNCRUISER 37G CLASS A RV (A60736)
2000 ITASCA...
SKIDDED WASTE WATER FIBERGLASS TANKS (A60736)
SKIDDED WASTE...
