Advice on building a tractor shed?
   / Advice on building a tractor shed? #101
I think what to build comes down to what your personal ability are.
If you aren't a builder and want 3 or 4 walls, a metal carport type structure is probably the best bet,
If you aren't a builder, want most sq ft and or most height, a hired in pole barn company is probably the best bet.
If you have some basic carpentry skills; building a pole barn is best.
If you can do block, and have the time; CMU is a good option. With that, you have to have good/easy access to the site with a block truck and a concrete truck
If you are a Good framer, and want the most finished space, but not as worried about max height or max square footage conventional framing is the easiest to finish out. Basically, finished detached garage.
If you just hate yourself, quanset hutt style; not very cheap, a pain to erect, almost impossible to finish interior,
   / Advice on building a tractor shed? #102
With the prefab metal pole barn roof trusses, you can get 12 ft wide bays. You use 2x6 purlions, attacked to the truss flange, in the upright position to get the 12 ft span. It does work, but in the kits; i dont like the idea of walking on 29 ga metal, with 12 ft spacing; just from an installation stand point.
So, the trusses for a 16 ft building will cost right around $200/ea; and you can free fly atleast 12" of metal past the last attachment; so; thats easily 18 ft of cover. The same truss for a 14 ft building is about $170. Unless there is a specific, hard, property/placement issue; I would go atleast 16 ft
   / Advice on building a tractor shed? #103
I wanted to keep tractor closer to driveway for snow clearing in winter. My neighbor gave me wood that was sawn on my property sawmill, new old stock, 40ish years ago. (was for a garage for his wife) While it will be a tight fit with ROPS down, it will fit. Still deciding on door style to keep snow out, as wind drifts it in front of garage and now lean to. Garage to inside post is 10'. 8' tall at garage down to 58" at post x26 feet long, as I can keep implements inside with plenty of room. Will have a temporary plastic sheathing on roof until that material is purchased. The best I could do with existing topography is 4:12 pitch, so I will have to do some snow raking if the snow doesn't slide all the way off. Garage is 5:12 with no issue of snow shedding on it's own. There is a 4+' rise going up to barn. Once I gather enough metal roofing, I'll lay purlins down on top of HD plastic.
   / Advice on building a tractor shed? #104
USDA standard plans can be downloaded for free:
   / Advice on building a tractor shed? #105
Took a quick peek at one of them - small guest house - plans date from 1948 - I do think, or at least I sure hope that building techniques and materials have improved in 75+ years. Some of the plans are dated 1930 - makes them 95 years old.
That isn't to say they are "bad", but I think they are obsolete at the very least.
Wonder how they'd update using light gauge steel, SIPS, aerated concrete, Simpson Strong-Ties, PVC pipe and so forth. Also the electric services are utterly inadequate for 2025.
They're interesting but I wouldn't build anything that way nowadays.
Best Regards.
Mike/Florida
   / Advice on building a tractor shed? #106
The 22x30x10 machinery shed; i mean, fundamentally, for a conventional framed; it just needs some updating; 1" plank roof, thats 7/16" osb; 30# felt under the slab, thats visqueen; 6/12 roof, thats pretty extreme in most of the country, a 4/12 is fine. Replace the forge with a welding table; remove the wood stove and add a window AC, ect.
They do have some "odd" details, like the stem wall is 10" above finish floor elev, and 4" wide "curb". Not sure what function that plays, and then you have a free floating, non tied in, 6" concrete floor. Man, monolithic, thick edge; or a stem wall with the slab tied into the footer blocks; not a separate system... Times change
   / Advice on building a tractor shed? #107
This 3 bed, 2.5 bath, home from 1980 is not far from what is built today. Yeah, replace that T1-11 with hardi, change that one kitchen wall to a knee wall with bar, remove some of the unneeded doors. It actually kinda surprised me with the number of outlets, and they appear pretty well placed
   / Advice on building a tractor shed? #108
Older homes had lots of doors to control how much space heated at a given time.
   / Advice on building a tractor shed? #109
You're right - we're still building this way. And we were building this way long before 1980 when these plans came out.
There are some materials changes, some uprated code requirements and some better components, but we are still building houses the same way as in the 1950s.
Friend of mine is building (more correctly having built) a real high-roller fancy big-buck house, it has been under construction for almost a year now and it is not particularly behind schedule.
It is built the same way the houses in the 1980 plans were built, start with a pile of 2 by 4s and sheets of plywood, and hammer it together one stick at a time. Slow and expensive, highly labor intensive. Lots of waste, too.
If we built cars this way, start with chunks of cast iron or aluminum, and a stack of steel sheets to make the bodies, plus a drill press, a hacksaw and some files, nobody could afford cars, they would be far too labor-intensive.
If we are ever to have even semi-affordable homes, we need to update the procedures and components. Instead of building walls one stick at a time in the field using saws and hammers, we should be building subassemblies in factories with automated machinery - faster, less expensive, more standardized, better quality control - and assembling houses like Lego blocks, semi-finished wall panels with insulation, plumbing and wiring already in place, assembled quickly on the job site.
But everyone wants their house to be unique! Our cars aren't unique (mass production is why we can [almost] afford them) and nobody complains that their neighbor's car has the same size tires as they do. Standard parts . . .
Unfortunately, there's a well deserved stigma for manufactured housing - a/k/a mobile homes, which are not exactly the finest representation of the builder's art.
If we took the techniques used in mobile home manufacturing and made standardized modules using quality components, we might be able to get the cost of homes down a little, get them built better and more quickly than now.
That's why pre-engineered steel buildings are (comparatively) inexpensive and go up fast. All the prep work and fabrication is done someplace else, inside, out of the weather, the "kit" shows up on a truck and is done in a few days - there's your building.
Is it going to change? Not any time soon. Most of the people I talk to, building inspectors, code people, lenders, even builders, say we are building houses now pretty much like we built them a hundred years ago. Materials are better, details change, but it is still slow, expensive, hand labor for stick built one at a time houses.
Best Regards,
Mike/Florida - who used to be a slumlord and knows lots of ways NOT to build houses . . .
   / Advice on building a tractor shed? #110
New 200 unit apartment buildings going up and just completed are as you describe… a crane lifting modular trucked in units in floors topping out 5 stories high…
I know 100 year old homes here that have aged phenomenally well…
Not sure how the modular 5 story builds will hold up…
We will know in a hundred years I suppose.
   / Advice on building a tractor shed? #111
Several TBN members are not into building, but have it delivered and dropped in the perfect spot to use. Most are delivered within 50 miles for free delivery.
A 8x20 runs $1,800 to $2,400.
8x20 deep.
   / Advice on building a tractor shed? #112
I'm arguing with the city/county building department about placing a pair of 30-ft shipping containers with side doors, 24-ft apart on a raised concrete foundation, then roofing over the gap and installing a metal roof system. The code explicitly forbids them, but being a licensed engineer, I have the legal right to go outside code. Their big objection is they are ugly. My argument is when I sheath them with LP Smart siding, they will look fine. And, it is the least expensive way to get a rodent proof, highly fire resistant structure. Working on drawing it up, so I can do architectural renderings.
   / Advice on building a tractor shed? #113
.If we took the techniques used in mobile home manufacturing and made standardized modules using quality components, we might be able to get the cost of homes down a little, get them built better and more quickly than now.
What you describe is a panelized house.
Back in the 90s, I visited a factory near Sacramento that was building panelized houses. Walls were built in a jig to standards that were higher than manufactured houses. But still 2x6 wood frame with wooden siding. The nearly-finished walls were trucked to the site and nailed together.
Around that time, I found a builder for a local friend to build his new house that way. After it was done, the builder said is was kind of a wash in terms of cost and speed. Framing a house might be 10% of the building effort after all.
Yeah, most houses in the US are built (framed) like they were 100+ years ago. Small changes in framing did happen: platform-framing instead balloon-framing around the turn of the 20th century. Plywood replaced planks after WW2. 2x6s now, instead of 2x4s for more insulation. Not exactly built to last.
   / Advice on building a tractor shed? #114
   / Advice on building a tractor shed? #115
All the tractors we have looked at are slightly to tall to fit in a high shipping container...
The same reason I want a 10 foot tall door for my tractor garage. I would like to get a bigger tractor within the next two years. My little Mahindra 1626 is down to 19HP due to altitude loss. I want a 40HP tractor so it won’t bug down when grading my roads and the land plane gets full going uphill.
2004 JOHN DEERE 160C LC EXCAVATOR (A52709)
2004 JOHN DEERE...
Bogballe L20W Plus (A53317)
Bogballe L20W Plus...
2017 CAT TL1055 (A60462)
2017 CAT TL1055...
UNUSED FUTURE POWER TROWEL (A60432)
UNUSED FUTURE...
2417 (A60432)
2417 (A60432)
2012 CATERPILLAR 257B3 SKID STEER (A60429)
2012 CATERPILLAR...
