Adjusting wheels
/ Adjusting wheels #1
ChrisC
Thanks all for the help I've received. I've stayed with the turf tires on my Kubota B2910 for the time being. I bought a set of chains from the local dealer, but there isn't enough clearance between the tires and the fender.
The dealer suggested I adjust the wheels. There's a spacer in between the wheel that needs to be flipped around.
I haven't done this before. Anything I need to know. I plan to borrow a jack from the neighbor.
I've worked on cars, so will follow the usual safety procedures: park in a level place, set the brake, block the wheels, etc.
Anything else I need to know?
Chris
/ Adjusting wheels #2
Hi Chris,
I'm not sure about your Kubota, but on my Ford the turf tires are adjusted by just turning them around. Gives a little extra room for chains, but unfortunately the valve stem ends up on the inside (not a huge problem). Hope this helps.
Dave
UNVERFERTH HT25 HEADER CART (A63291)
UNVERFERTH HT25...
2019 Ford F-450 Flatbed Truck (A64194)
2019 Ford F-450...
JOHN DEERE 1730 - 6R40", 11R20" VACUUM PLANTER (A64278)
JOHN DEERE 1730 -...
2016 Ford Explorer AWD SUV (A64557)
2016 Ford Explorer...
New/Unused Mini Quick Attach Auger with Bit (A65583)
New/Unused Mini...
2024 JOHN DEERE TURF GATOR TX 4X2 UTV (A63276)
2024 JOHN DEERE...
