adjusting brush hog
/ adjusting brush hog #31
Freds, you may be overtightening them. Yes, with the pins turned inward the "pull" of the 3 -point lower arms will be on the clevis pins. No--I have never bent them despite heavy work on my Boxblade which I did the same way. I have seen them done this way even in some implement brochures and my Kubota dealer says they do it all the time. I think the outer position would be the prefered one but turning them inward is entirely acceptable and will not cause you any problems. J
The dealer told me to adjust mowers and hogs so that when you push on the side of them the tractor moves. I turn the turnbuckle on the check chain by hand to adjust.
I put the mower back on today and the pins were fine even though I had to give the 3 pt. a kick to break things loose after I had loosened thing up. I suppose you _could_ bend a pin, just wondered if you ever saw it happen.
Thanks,
Fred
/ adjusting brush hog #33
I doubt you will bend a clevis if it is the large size intended for that pin. J
2013 Ford F-250 Pickup Truck (A55973)
2013 Ford F-250...
2018 Chevrolet Trax SUV (A61569)
2018 Chevrolet...
CFG Industry MX12RX (A60463)
CFG Industry...
Toro Greensmaster 3150-Q Riding Mower (A56859)
Toro Greensmaster...
2020 CATERPILLAR 259D3 SKID STEER (A62129)
2020 CATERPILLAR...
Tafe 45DI (A60462)
Tafe 45DI (A60462)
