Dargo
Super Member
- Joined
- Mar 6, 2004
- Messages
- 5,974
- Location
- S. IN
- Tractor
- Jinma, Foton, TYM, Belarus, Yanmar, Branson, Montana, Mahindra and maybe some green and orange too.
Since I have a JD 5525, a friend called me to ask me to help with an issue on his 5325 that he says has the same loader. I haven't been there yet for an in-depth look, but he tells me that the right front edge of his bucket hits the ground 2" before the left front does. Thinking the bucket or QA may be bent, I asked him to take the bucket off and just measure the pivot point distances from the ground. They measured the same; the right side was 2" lower than the left side.
Looking at how my loader is attached, I'm not sure I can see an easy way to adjust his loader arms. My only guess is that the very top bolt that bolts horizontally from the front going towards the rear of the tractor has a washer on it (both sides). If he added some washers to the left side top bolt that I'm talking about, wouldn't that lower the left front arm on his loader? I see no way to get his right side (which is lower) up. Would this work; lowering the left side loader arm to get it close to his right side? I backed that top bolt out on mine and it seemed to have several inches of threads on the 26mm bolt.
I haven't spent a lot of time ciphering on the matter, but it seems like there should be some way for him to correct this problem. When I quickly looked at his tractor I noticed that the right front edge of his (replaceable) bucket edge was worn quite a bit more than his left side. This tells me that he has had this issue for a while. Actually, he bought the tractor used and has only had it for about a year. It's entirely possible he bought it this way. No matter, he loves the tractor and clearly intends on keeping it. However, buying a new loader seems out of the question and not a reasonable option at this point. Any thoughts how he can fix his problem? I'm his "tractor guy", but I've never run across this issue. Hopefully the brain trust here will be able to give me a solution.
P. S. I did ask him to check tire pressures (thinking they could cause one side to be lower than the other), but he said they were within a pound or two of being even.
