Loader Adjust uneven loader arms?
/ Adjust uneven loader arms? #1
Dargo
Super Member
S. IN
Jinma, Foton, TYM, Belarus, Yanmar, Branson, Montana, Mahindra and maybe some green and orange too.
Since I have a JD 5525, a friend called me to ask me to help with an issue on his 5325 that he says has the same loader. I haven't been there yet for an in-depth look, but he tells me that the right front edge of his bucket hits the ground 2" before the left front does. Thinking the bucket or QA may be bent, I asked him to take the bucket off and just measure the pivot point distances from the ground. They measured the same; the right side was 2" lower than the left side.
Looking at how my loader is attached, I'm not sure I can see an easy way to adjust his loader arms. My only guess is that the very top bolt that bolts horizontally from the front going towards the rear of the tractor has a washer on it (both sides). If he added some washers to the left side top bolt that I'm talking about, wouldn't that lower the left front arm on his loader? I see no way to get his right side (which is lower) up. Would this work; lowering the left side loader arm to get it close to his right side? I backed that top bolt out on mine and it seemed to have several inches of threads on the 26mm bolt.
I haven't spent a lot of time ciphering on the matter, but it seems like there should be some way for him to correct this problem. When I quickly looked at his tractor I noticed that the right front edge of his (replaceable) bucket edge was worn quite a bit more than his left side. This tells me that he has had this issue for a while. Actually, he bought the tractor used and has only had it for about a year. It's entirely possible he bought it this way. No matter, he loves the tractor and clearly intends on keeping it. However, buying a new loader seems out of the question and not a reasonable option at this point. Any thoughts how he can fix his problem? I'm his "tractor guy", but I've never run across this issue. Hopefully the brain trust here will be able to give me a solution.
P. S. I did ask him to check tire pressures (thinking they could cause one side to be lower than the other), but he said they were within a pound or two of being even.
/ Adjust uneven loader arms? #2
Bent or I suspect is set up wrong.
There are procedures for installing the brackets and adjustments that can (and should) be made. If he can't decipher where they are at, then have him stop by his dealer and get the set-up paperwork.
/ Adjust uneven loader arms? #3
Is he close enough to bring his tractor to your location? If so, have him do that and put his loader on your tractor. If it is OK on your tractor his mounts are the problem. If it is not level on your tractor the loader is bent/sprung. Good luck.
/ Adjust uneven loader arms? #4
Maybe a bent cylinder rod that is binding, not fully retracting? Something else to check.
/ Adjust uneven loader arms? #5
I know this will sound too simple, I have seen the same thing with an under inflated tire. May not be obvious at a glance, yet can make a big differance.
MarkV
MarkV
Thanks, that's why I added the "P.S." to the post. I agree with you, but I remembered to ask him that.
Zebra5, I hate to sound unhelpful to the guy, because I'd like to help. I just don't have the time or want to go through the trouble of putting his loader on my tractor.
He's out of warranty and is terrified of the expense of taking anything to a dealer. That's why I'm trying to come up with some fix. I think I should have the FEL manual at home since I bought my tractor new. Wouldn't my JD 5525 have come with a separate FEL manual, or am I mistaken? If so, maybe there is something in there about how to adjust his loader arms. Just because I haven't personally run across it, I have to think this isn't all that uncommon. He borrowed my 3/4" ratchet and socket set and said everything was tight.
I'm still scratching my head. It seems like there would be some adjustment somewhere, doesn't there? Or not? I really don't know.
Dang, another senior moment! Sorry Dargo, I missed the P.S. :confused:
MarkV
Oh, no "sorry" please. I'm open for ideas. And, since that was in the "P.S." area, it was one that I thought about later and called him to check. Trust me, it wasn't one of my first thoughts. Thanks for the suggestion!
/ Adjust uneven loader arms? #9
Don't hurry to rush past the obvious.
Check front tire pressures before going any farther.
It doesn't much matter WHAT they are, just that they are (approx) the same as each other.
Could save Y'self a lot of time and trouble.
EDIT:
Ooops, Sorry MartkV, I missed your post the first time through.
/ Adjust uneven loader arms? #10
YES, there is adjustment.
If you post some pics of the FEL, will prolly be able to point to where they are. But not off the top of my head. :)
/ Adjust uneven loader arms? #11
You shoulda got a separate manual for the loader. Might be able to find it on the JD website, too.
'Course your (or his) dealer should be willing to photocopy the adjustment pages from the technical repair or owner's manual.
Good luck.
AKfish
I suppose I could post pics of my loader (assuming he's right and they are the same) if someone could possibly point out on it where the adjustments are. I could then be a hero and show him how to adjust his. :D
/ Adjust uneven loader arms? #13
Have you got a long carpenter's level? One that will extend across the top of the vertical loader masts?
If the mast tops are pretty level (assuming level parking area and tires) and fairly even - then he's likely got loader arm problems.
If they're not even - then it's time to readjust the mounts.
If the loader arms have been tweaked - you might also run the level along (spanned across the top) the loader arms to see where any difference between them starts (place where it's been tweaked..).
Hope it's not a 542SL; bars accross the loader arms..
AKfish
/ Adjust uneven loader arms? #14
Have you ever used a "Water Level" - Very accurate
Simple device made from plastic tubing and colored water.
Just park the tractor on a level floor or parking lot and use the water level to check side to side on any part of the tractor or loader.
You can "google" water level to see how it works
/ Adjust uneven loader arms? #15
I found my loader bucket also was uneven!
Parked it on a level spot and started checking around to locate the cause.
Turned out to be an elongated bolt hole where the loader frame attached to the tractor sub frame.
A mere 1/8" (or so) elongation multiplied by the arms lengths and angles resulted in nearly 2-3 inches of difference between the bucket corners.
My 'cure' was to jack the arm frame back to level and max torque the offending bolt and then a nice weld bead to prevent movement.
I figure that if i ever need to remove the frame, a mere couple if minutes with the grinder will erase the weld.
Shows that we should check torques more often than we think!
BOAT MOTOR (A66738)
BOAT MOTOR (A66738)
CAT R450/D9H Ripper Teeth (8) (A68134)
CAT R450/D9H...
2019 Cadillac XTS Stretch Limousine for Sale, S and S Coachbuilders, 70IN, 7731 Miles (A63689)
2019 Cadillac XTS...
2001 Belshe Backhoe Trailer (A64194)
2001 Belshe...
2022 PETERBILT 389 (A67714)
2022 PETERBILT 389...
2012 CHEVROLET SILVERADO 1500 (A67714)
2012 CHEVROLET...
