Adjust The "Air" Pressure??
/ Adjust The "Air" Pressure?? #1
CADplans
Elite Member
near Roanoke VA
584 IH 4WD
The rear tires look like the air pressure is too low,,,
Would you increase the air pressure??
Maybe the tires need to be filled with fluid?
Too many tire plugs?
What do you think??
/ Adjust The "Air" Pressure?? #3
Don't over-inflate traction tires. The more lugs in contact with the ground, the better they work. The front tires look over-inflated to me.
/ Adjust The "Air" Pressure?? #9
Ive had airless tires before, was not impressed with them at all. Mine wasnt the Twheel brand, Im pretty sure they were called Flat😂
Those airless tires are a godsend on debris laden job sites.
/ Adjust The "Air" Pressure?? #10
Three or four years ago the local JD dealer had one of those Z760R mowers for sale. Those tweedle-de wheels had better be the best thing since sliced bread. One wheel was $675 at that time.
I wonder if there has been any advancement made in this direction. Such as a replacement for the 16.9 x 28 tires on my M6040.
/ Adjust The "Air" Pressure?? #11
From the lawnsite forum, the general consensus seems to be that these things are great. Good grip on hills, often better than the traditional wheels. I have never used them in person though, and unless you are going from commercial site to commercial site with lots of debris, might not be worth the price tag for an average customer.
Question I have is weight. Filled tires are mighty popular around here, and I think you would find half the community would shun these unless they were heavy, or a way to make them so was introduced. Who knows maybe they could use a heavier polymer when making the tractor ones.
2016 Ford Expedition SUV (A66738)
2016 Ford...
2018 GENERAC MOBILE PRODUCTS MLT6S (A68842)
2018 GENERAC...
Unused 2023 Monroe Tufline TW693222 12ft. Pull Behind Disc Harrow Tractor Attachment (A66734)
Unused 2023 Monroe...
2004 NiftyLift TM50 HGE 50ft Towable Articulating Boom Lift (A66734)
2004 NiftyLift...
1995 Khronert 307 SS Single Comp 6,500 Gallon Insulated T/A Chemical Tanker Trailer (A68183)
1995 Khronert 307...
Gravely Pro-Turn 148 50in Zero Turn Commercial Mower (A66734)
Gravely Pro-Turn...
